黑光发生器电路 Black Light
电源电路图
835人已加入
黑光发生器电路 Black Light
This circuit is a simple ultraviolate light that can be powered by a 6 volt battery or power supply that is capable of supplying 1 or more amps.
发生器电路
Theoritical Diagramm
发生器电路发生器电路
PARTS
Part   Total Qty.   Description
C1 1 0.0047uf Mono Capacitor
C2 1 0.1uf Disc Capacitor
D1, D2 2 1N4007 Diode
FTB 1 Filtered Blacklight Tube
IC1 1 555 Timer IC
P1 1 10k Trim Pot
Q1 1 TIP30 PNP Power Transistor
R1 1 470 Ohm Resistor
R2 1 270 Ohm Resistor
T1 1 Medium Yellow Inverter Transformer
MISC 1 IC Socket, Heat Sink For Q1, Screw, Nut, Wire and PC Board
Notes:
1. P1 changes brightness of the black light tube.
[责任编辑:电子发烧友---转载请标明出处]
