MAX3095, MAX3096 ±15kV ESD保护、1
新品快讯
29人已加入
MAX3095, MAX3096 ±15kV ESD保护、10Mbps、3V/5V、四路RS-422/RS-485接收器
概述
The MAX3095/MAX3096 are rugged, low-power, quad, RS-422/RS-485 receivers with electrostatic discharge (ESD) protection for use in harsh environments. All receiver inputs are protected to ±15kV using IEC 1000-4-2 Air-Gap Discharge, ±8kV using IEC 1000-4-2 Contact Discharge, and ±15kV using the Human Body Model. The MAX3095 operates from a +5V supply, while the MAX3096 operates from a +3.3V supply. Receiver propagation delays are guaranteed to within ±8ns of a predetermined value, thereby ensuring device-to-device matching across production lots.
Complementary enable inputs can be used to place the devices in a 1nA low-power shutdown mode in which the receiver outputs are high impedance. When active, these receivers have a fail-safe feature that guarantees a logic-high output if the input is open circuit. They also feature a quarter-unit-load input impedance that allows 128 receivers on a bus.
The MAX3095/MAX3096 are pin-compatible, low-power upgrades to the industry-standard '26LS32. They are available in a space-saving QSOP package.
关键特性
  • ESD Protection:
    • ±15kV-IEC 1000-4-2, Air-Gap Discharge
    • ±8kV-IEC 1000-4-2, Contact Discharge
    • ±15kV-Human Body Model
  • Guaranteed Propagation-Delay Tolerance Between All ICs:
    • ±8ns (MAX3095)
    • ±10ns (MAX3096)
  • Single +3V Operation (MAX3096)
  • Single +5V Operation (MAX3095)
  • 16-Pin QSOP (8-pin SO footprint)
  • 10Mbps Data Rate
  • Allow up to 128 Receivers on the Bus
  • 1nA Low-Power Shutdown Mode
  • 2.4mA Operating Supply Current
  • 应用/使用
  • 电平转换器
  • ESD敏感应用的接收器
  • 嘈杂环境的RS-422/RS-485/RS-423总线接收器
  • 电信设备
    485
    功能框图
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
    • 485
