MAX2135 Diversity tuner for au
新品快讯
30人已加入
MAX2135 Diversity tuner for automotive TV applications provides two tuners in a 7mm x 7mm package
Dual-tuner IC provides reception diversity in automotive TV applications.
SUNNYVALE, CA—January 25, 2010—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX2135 diversity tuner for ISDB-T and DVB-T automotive applications. This device integrates two high-performance signal paths that operate from a single fractional-N synthesizer. Packaged in a small, 7mm x 7mm TQFN, the MAX2135 provides a compact solution compared to designs that use two separate tuner ICs. Additionally, the device features a very low, 3.8dB (typ) UHF noise figure, and it consumes only 330mW when both signal paths are active and 200mW when only one path is active. Uniquely combining a small footprint with low power consumption and low noise, the MAX2135 is ideal for automotive in-dash navigation and entertainment systems.
A versatile device, the MAX2135 receives signals in three bands: VHF-low, VHF-III, and UHF. Furthermore, on-chip lowpass filters accommodate 4, 6, 7, and 8MHz signal bandwidths, making the device ideal for receiving Japan's ISDB-T and Europe's DVB-T broadcasts. The output of each signal path is a 4MHz, low-IF signal that interfaces to most demodulator ICs. Additional features that reduce the external BOM price include on-chip tracking filters, a reference oscillator, and LNAs.
The MAX2135 is available in a small, 7mm x 7mm, 56-pin TQFN package, and is fully specified over the -40°C to +85°C extended temperature range. Pricing starts at $8.00 (1000-up, FOB USA). An evaluation kit is available to speed designs.
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6200 products serving the industrial, communications, consumer, and computing markets.
  • 相关推荐
  • 热点推荐
  • tuner
