MAX16922 2.2MHz、双通道、降压型DC-DC转换器,带有两路LDO和/RESET功能
概述
The
MAX16922 power-management integrated circuit (PMIC) is designed for medium power-level automotive applications and integrates multiple supplies in a small footprint. The device includes one high-voltage step-down converter (OUT1) and three low-voltage cascaded DC-DC converters (OUT2, OUT3, OUT4). OUT1 and OUT2 are step-down DC-DC converters, and OUT3/OUT4 are linear regulators. The device also includes a reset output (active-low RESET) and a high-voltage-compatible enable input (EN).
The 1.2A output high-efficiency, step-down DC-DC converter (OUT1) operates from a voltage up to 28V continuous and is protected from load-dump transients up to 45V. The 600mA output high-efficiency step-down DC-DC converter (OUT2) runs from a voltage up to 5.5V. The two 300mA LDO linear regulators offer low dropout of only 130mV (typ). The power-good active-low RESET output provides voltage monitoring for OUT1 and OUT2.
OUT1 and OUT2 use fast 2.2MHz PWM switching and small external components. The high-voltage converter (OUT1) enters skip mode automatically under light loads to prevent an overvoltage condition from occurring at the output. The low-voltage synchronous DC-DC converter (OUT2) can operate in forced-PWM mode to prevent any AM band interference or high-efficiency auto-PWM mode.
The MAX16922 includes overtemperature shutdown and overcurrent limiting. All devices are designed to operate from -40°C to +125°C ambient temperature.
关键特性
1.2A High-Efficiency 2.2MHz DC-DC Converter
- 3.7V to 28V Operating Supply Voltage
- 45V Load-Dump Protection
- Output Voltage: 3.0V to 5.5V
600mA High-Efficiency 2.2MHz DC-DC Converter
- 2.7V to 5.5V Supply Voltage
- Output Voltage: 1.0V to 3.9V
- 180° Out-of-Phase Operation
- Forced-PWM and Auto-PWM Modes
LDO Linear Regulators
- OUT3: 1.0V to 4.15V at 300mA
- OUT4: 1.0V to 4.15V at 300mA
- Separate Inputs for Increased Efficiency
Enable Input
Active-Low RESET Output Monitoring on OUT1 and OUT2
Overtemperature and Short-Circuit Protection
Available in
- 5mm × 5mm × 0.8mm, 20-Pin TQFN-EP
- 4.5mm × 6.5mm, 20-Pin TSSOP-EP
应用/使用
汽车
Typical Operating Circuit
