投影机位置计算和吊装技巧
投影机
9人已加入
投影机位置计算和吊装技巧
CP-310t 电动变焦镜头
投影距离 屏幕尺寸
最短焦距 最长焦距
英寸 英寸 英寸 英寸 英寸 英寸
5.00 60.0 2.41 29.0 3.14 37.7
5.50 66.0 2.66 31.9 3.46 41.5
6.00 72.0 2.90 34.8 3.77 45.2
6.50 78.0 3.14 37.7 4.08 49.0
7.00 84.0 3.38 40.6 4.40 52.8
7.50 90.0 3.62 43.5 4.7 56.5
8.00 96.0 3.86 46.4 5.03 60.3
8.50 102.0 4.11 49.3 5.34 64.1
9.00 108.0 4.35 52.2 5.65 67.9
9.50 114.0 4.59 55.1 5.97 71.6
10.00 120.0 4.83 58.0 6.28 75.4
10.5 126.0 5.07 60.9 6.60 79.2
11.00 132.0 5.31 63.8 6.91 82.9
11.50 138.0 5.55 66.7 7.23 86.7
12.00 144.0 5.80 69.5 7.54 90.5
12.5 150.0 6.04 72.4 7.85 94.2
13.00 156.0 6.28 75.3 8.17 98.0
13.50 162.0 6.52 78.2 8.48 101.8
14.00 168.0 7.76 81.1 8.80 105.6
14.50 174.0 7.00 84.0 9.11 109.3
15.00 180.0 7.24 86.9 9.42 113.1
15.50 186.0 7.49 89.8 9.74 116.9
16.00 192.0 7.32 92.7 10.05 120.6
16.50 198.0 7.97 95.6 10.37 124.4
17.00 204.0 8.21 98.5 10.68 128.2
17.50 210.0 8.45 101.4 11.00 131.9
18.00 216.0 8.69 104.3 11.31 135.7
18.50 222.0 8.94 107.2 11.62 139.5
19.00 228.0 9.18 110.1 11.94 143.3
195.50 234.0 9.42 113.0 12.25 147.0
20.00 240.0 9.66 115.9 12.57 150.8
20.50 246.0 9.90 11.8 12.88 154.6
21.00 252.0 10.14 121.7 13.19 158.3
21.50 258.0 10.38 124.6 13.51 162.1
22.00 264.0 10.63 127.5 13.82 165.9
22.50 270.0 10.87 130.4 14.14 169.6
23.00 276.0 11.11 133.3 14.45 173.4
23.50 282.0 11.35 136.2 14.77 177.2
24.00 288.0 11.59 139.1 15.08 181.0
24.50 294.0 11.83 142.0 15.39 184.7
25.00 300.0 12.07 144.9 15.71 188.5
25.50 306.0 12.32 147.8 16.02 192.3
26.00 312.0 12.56 150.7 16.34 196.0
26.50 318.0 12.80 153.6 16.65 199.8
27.00 324.0 13.04 156.5 16.96 203.6
27.50 330.0 13.28 159.4 17.28 207.3
28.00 336.0 13.52 162.3 17.59 211.1
28.50 342.0 13.76 165.2 17.91 214.9
29.00 348.0 14.01 168.1 18.22 218.7
29.50 354.0 14.25 171.0 18.54 222.4
30.00 360.0 14.49 173.9 18.85 226.2
30.50 366.0 14.73 176.8 19.16 230.0
31.00 372.0 14.79 179.7 19.48 233.7
31.50 378.0 15.21 182.6 19.79 237.5
32.00 384.0 15.46 185.5 20.11 241.3
32.50 390.0 15.7 188.4 20.42 245.0
33.00 396.0 15.94 191.3 20.73 248.8
33.50 402.0 16.18 194.2 21.05 252.6
34.00 408.0 16.42 197.1 21.36 256.4
34.50 414.0 16.66 200.0 21.68 260.1
35.00 420.0 16.90. 202.9 21.99 263.9
35.50 426.0 17.15 205.7 22.31 267.7
36.00 432.0 17.39 208.6 22.62 271.4
36.50 438.0 17.63 211.5 22.93 275.2
37.00 444.0 17.87 214.4 23.25 279.0
37.50 450.0 18.11 217.3 23.56 282.7
38.00 456.0 18.35 220.2 23.88 286.5
38.50 462.0 18.59 223.1 24.19 290.3
39.00 468.0 18.84 226.0 24.50 294.1
39.50 474.0 19.08 228.9 24.82 297.8
40.00 480.0 19.32 231.8 25.13 301.6
投影机与屏幕位置计算
你决定购买哪一款投影机和投影屏幕之前,应该先搞清楚安装这些设备的房间的相关信息。比如房间的光照情况如何?你打算把投影机安装在桌子上还是可移动的小车上?房间的长、宽、高等尺寸是多少?是使用轻便式屏幕还是固定安装屏幕?屏幕位置设在何处?观众座位在何处?
不管你是否安装这些设备,回答了这些问题有助于你确定新购投影机相对于屏幕的最佳位置,使你能得到可能的最大尺寸图像。
你确实只需了解投影机的两个技术指标——投射距离和图像尺寸(对角线值),便可确定投影机与屏幕的距离。BOXLIGHT CP-310t投影机的投射距离为5.2英尺至40英尺,图像尺寸为31英寸至300英寸,就是说:投影距离为5.2英尺时,投射出的图像尺寸为31英寸,投影距离为40英尺时,投射的图像尺寸达300英寸。为免去你重修中学几何知识之苦,BOXLIGHT为我们销售的每台投影机配备了一张投射图表。通过BOXLIGHT网址可下载投射图表。数据以图形和表格两种形式表现。这两套数据包含了在最小焦距和最大焦距值时投影机到屏幕的距离和所投射出的图像尺寸(对角线值)。
比方说,你打算在起居室放置一台cp-310t,还有一块对角线为150英寸的Da-Lite Image NTSC格式固定墙面安装屏幕。你的起居室尺寸为15×25英尺,屏幕安装在15英尺宽的墙上,你想得到最大的图像。那么投影机安装位置应该离屏幕墙多远呢?下面表格中,从最大焦距一栏开始往下查,可找到接近150英寸对角值,顺着这一行向左边查,就可确定投影机离显示屏的距离了。在最小焦距一栏用同样的方式可找到20至25.5英尺间的距离,在这个距离安装投影机就可以得到150英寸对角尺寸的图像。因为你的房间是25英尺长,所以你的投影距离应该小于房间长度。如果你的房间较小,可选用配备短投射镜头的CP-306t投影机,它也可以在11.5至13.5英尺的投射距离投出相同尺寸的图像。
在天花板上安装投影机
如果你没有实际经验,在天花板上安装投影机可能是很麻烦的事情。有时,在天花板上安装投影机很简单,就象把天花板放在龙骨上面一样,或者把支撑杆安装到墙体结构上一样简单。有时,在天花板上安装投影机是很有创意的。我将告诉你在天花板上安装投影机的一些要素:天花板类型、安装类型、投影机类型、投射距离和安全要求。解决了这些不同的问题有助于你确定在天花板上安装投影机的最佳方案。
首先搞清楚下面一些问题:
天花板类型
教堂式天花板——非常高
结构式天花板——八英尺高的非教堂式天花板,通常是封闭的。
悬吊式天花板——办公楼中的片式天花
安装类型
教堂式天花板安装件
圆形天花板安装件
吊顶天花板套件
你想把投影机与天花板之间采用平行安装还是悬吊安装?与天花板平行安装时投影机与天花板之间的距离为4到6英寸,平行安装不适合于教堂,但适用于结构式和吊挂式天花。
投影机类型
你要知道将安装的投影机型号。投影机安装板是与型号严格对应的,某种类型的安装板只与某种类型的投影机安装孔严格对应,不同型号的投影机安装孔也不相同,大部分投影机是倒挂在天花板上,投影机里有正确倒换图像的菜单选择。
投射距离
你必须知道,要在指定的屏幕上投射出大小合适的图像,你要在离屏幕多远的地方安装投影机。不同类型的投影机投射的图像尺寸各不相同。投影机生产商做的“投射距离与图像尺寸表”列出子图像尺寸与投影机到屏幕距离的数据。在安装投影机之前你必须参考此图表。
安全要求
应当考虑投影机防盗问题。如果投影机安装在非常显眼的地方,那么对投影机应当采取某种安全措施。不同的投影机要采取不同的安全措施,下面举例其中两种。第一种选择是购买投影机安装夹具。夹具夹住投影机的两侧,保证投影机不会被人从安装架上卸下。这种保护方式是用一套特殊螺钉固定的,这种特殊螺钉得用特殊扳手才能卸下。第二种选择是和安全线缆。安全线缆通过锁具系牢投影机的一边。线缆再系牢在天花板安装架上。这些安全措施可防止投影机被盗,防止人们从支架上取下投影机并顺手牵羊。
通风
通风出入口会影响投影机冷却系统的性能。大部分生产厂商建议为投影机的通风口留出三英尺半径的空当。
眼下一切就绪,准备安置投影机。在教堂工和结构式天花板这两种情况,你可以将投影机安置在现有的建筑结构上。吊顶天花板结构中,投影机直接固定天花板安装架上。在上述任何一情况下,你都要使用延伸杆使投影机下降到屏幕的高度,或者与天花板平行安装。全部安装架都带有倾斜调节、平衡调节或偏转角调节,用于调整显示在屏幕上的图像。但这并非意味着你可以不用投影机的其它功能去校正图像。如果投影机安装得好,则这些倾斜调节、平衡调节或偏转角调节将保证投影机投射出四四方方的图像。请记住每一次安装都是不同的,但是,如果你遵循这些基本指导原则,则在天花板上安装投影机时遇到的关痛问题应当极少。
  • 相关推荐
  • 热点推荐
