电磁兼容(EMC)术语缩写中英文对照
电子常识
2680人已加入
电磁兼容(EMC)术语缩写中英文对照
a.c.or AC
alternating current交流电
ACEC
advisory committee on electromagnetic compatibility电磁兼容顾问委员会
ADSL
asymmetric DSL非对称数字用户环路
AE
auxiliary equipment辅助设备
AF
audio frequency音频
AM
amplitude modulation调幅
AN
access network接入网
ANE
access network equipment 接入网设备
CDMA
code division multiple access码分多址
CDN
coupling/decoupling network 耦合/去耦网络
CIGRE
international conference on large HV electric systems 国际大电网会议
CISPR
international special committee on radio interference 国际无线电干扰特别委员会
CPE
customer premises equipment 用户驻地设备
CRT
cathode ray tube 阴极射线管
d.c.or DC
direct current 直流电
dpf
dedicated power feed 专用供(馈)电
DSL
digital subscriber loop 数字用户环路
EFT/B
electrical fast transient /burst 电气快速瞬变/突发
EIRP
equivalent isotropically radiated power 等效全向辐射功率
EMC
electromagnetic compatibility 电磁兼容性
emf
electro-morive force 电动势
EMF
electro-magnetic field 电磁场
EPR
earth potential rise 地电位升高
ERP
effective radiated power 有效辐射功率
ESD
electrostatic discharge 静电放电
EUT
equipment under 受试设备
GDT
gas discharge tube 气体放电管
GV
high voltage 高电压
ICNIRP
international commission on non-ionizing radiation protection 国际非电离辐射保护委员会
IEC
international electrotechnical commission 国际电工委员会
ISDN
integrated services digital network 综合业务数字网
ISM
industrial, scientific and medical (equipment) 工业的,科学的和医学的(设备)
ITE
information technology fquipment 信息技术设备
ITU-T
international telecommunication union-telecommunication standardization sector
国际电信联盟电信标准局
LCL
longitudinal conversion loss 纵向转换损耗
LCTL
longitudinal conversion transfer loss 纵向转换传输损耗
LE
local exchange 本地交换
LEMP
lightning electromagnetic pulse 雷电电磁脉冲
LI
line interface 线路接口
LPS
lightning protection system 雷电保护系统
LPZS
lightning protection zone 雷电保护区
LT
line termination 线路终端
MDF
main distribution frame 总配线架
MOV
metal-oxide varistor 金属氧化压敏电阻
n.a.
not applicable 不可用
NT
network termination 网络终端
OATS
open area test site 开阔试验场
o/c
open circuit 开放电路
pfv
power feeding voltage 供电电压
PNI
public network interface 公用网接口
PRBS
pseudo random bit sequence 伪随机比特序列
PSTN
public switched telephone network 公用交换电话网
PTC
positive temperature coefficient(resistor) 正温度系数
RF
radio frequency 无线电频率
RFI
radio frequency interference 射频接口
RFT
remote feeding telecommunications circuit 远供通信电路
RFT-G
remote feeding telecommunications circuit-current limited 远供通信电路-限电流
RFT-V
remote feeding telecommunications circuit-voltage limited 远供通信电路-限电压
RSE
remote switching fquipment 远端交换设备
SA
specific absorption 比吸收能
SA
semi-conductor arrester 半导体避雷器
SAA
semi-conductor arrester assembly 半导体避雷器组件
SAR
specific absorption rate 吸收率
SAP
specific absorption power 吸收功率
SELV
safety extra low voltage 安全超低电压
SLIC
subscriber line interface circuit 用户线路接口电路
SPD
surge protective device 浪涌保护元件
SPL
sound pressure level 声压级
SSA
solid state arrester 固体避雷器
TCE
telecommunication centre equip电信中心设备
TDMA
time division multiple access 时分多址
TN
trunk network 干线网
TNV
telecommunication network voltage 电信网电压
RSD
universal serial bus 通用串联总线
RPS
uninterruptible power supply 不间断电源
VDSL
very high speed DSL 调整用户数字环路
VDU
visual display unit 视频显示单元
UIC
international union of railway 国际铁路联盟
xDSL
digital subscriber loop x数字用户环路
