镀24K金'雪花'提高石墨的电学性能
电池材料
6人已加入
镀24K金'雪花'提高石墨的电学性能
24-carat Gold 'Snowflakes' Improve Graphene's Electrical Properties
— In an effort to make graphene more useful in electronics applications, Kansas State University engineers made a golden discovery -- gold "snowflakes" on graphene.
Vikas Berry is a K-State assistant professor of chemical engineering who works with graphene, a carbon material only a single atom thick and discovered just five years ago. To functionalize graphene with gold -- thus controlling its electronics properties -- Berry and Kabeer Jasuja, a K-State doctoral student in chemical engineering, imbedded gold on graphene.
To do this, the engineers placed the graphene oxide sheets in a gold ion solution that had a growth catalyst. Here, the atomically thick sheets swim and bathe in a pool of chemicals.
"Graphene-derivatives act like swimming molecular carpets when in solution and exhibit fascinating physiochemical behavior," Berry said. "If we change the surface functionality or the concentration, we can control their properties."
They found that rather than distributing itself evenly over graphene, the gold formed islands on the sheets' surfaces. They named these islands snowflake-shaped gold nanostars, or SFGNs.
"So we started exploring how these gold nanostars are formed," Berry said. "We found out that nanostars with no surface functionality are rather challenging to produce by other chemical processes. We can control the size of these nanostars and have characterized the mechanism of nucleation and growth of these nanostructures. It's similar to the mechanism that forms real snowflakes."
Berry said the presence of graphene is critical for the formation of the gold nanostars. "If graphene is absent, the gold would clump together and settle down as big chunks," he said. "But the graphene helps in stabilizing the gold. This makes the nanostars more useful for electronic applications."
In July, Jasuja and Berry published their work in the journal ACS-Nano.
The discovery of these gold "snowflakes" on graphene shows promise for biological devices as well as
electronics. Berry is attaching DNA to these gold islands to make DNA sensors. He is joined by Nihar Mohanty, a doctoral student in chemical engineering, and undergraduate researcher Ashvin Nagaraja, a senior in electrical engineering. Nagaraja is a 2004 Manhattan High School graduate.
Berry said graphene-gold based DNA sensors will have enhanced sensitivity. Chemically reducing graphene oxide to obtain graphene requires harsh chemicals that destroy the DNA.
"Now we can use the harsh chemicals on graphene oxide imbedded with gold to obtain graphene with gold islands. Then we can use these gold islands to functionalize DNA."
Berry also is using graphene in conjunction with microwaves. He and Jasuja are "cooking" the graphene sheets as another way to produce particles on the material's surface.
Some of Berry's other graphene research involves using the modified graphene sheets to compartmentalize a coagulating solution, thus stabilizing it. His group has recently used hydrides to reduce graphene oxide to produce reduced graphene oxide in the matter of a few seconds. The graphene produced in this way can remain stable in the solution for several days. Further results will shortly appear in the journal Small
Discovered only five years ago, graphene has captured the attention of a large number of researchers who are studying its exceptional electrical, mechanical and optical properties, Berry said. His research group is among the few studying the material's interfacial properties and biological applications.
"We're entering a new era," Berry said. "From the zero-dimensional or one-dimensional molecular or polymer solutions, we are now venturing into the two-dimensional graphene solutions, which have fascinating new properties."
24-克拉黄金’雪片’改善 Graphene 的电特性
—为了在电子学申请中让 graphene 变成更有用,堪萨斯州立大学工程师作一项金的发现--在 graphene 上的金色 " 雪片 "。
Vikas 草莓类植物是以 graphene 工作的化学工程的 a K-州助理教授,碳材料只有一粒原子厚的而且只有五年前发现。用黄金使起作用 graphene --如此控制它的电子学特性--草莓类植物和 Kabeer Jasuja, a K-州博士的学生在化学工程,在 graphene 上使插入黄金。
要做这,工程师放置了 graphene 氧化物有了一个生长催化剂的金色离子解决的床单。在这里,原子厚的床单在一个化学药品的池游泳而且沭浴。
"Graphene-引出之物实行分子的地毯当在解决方面而且展现迷人的 physiochemical 行为, " 草莓类植物说。" 如果我们改变表面的功能性或者集中,我们能控制他们的财产 " 。
他们发现宁可超过平均地在 graphene 之上分配它本身,黄金在床单表面上形成了岛。他们命名这些岛雪片形的金色 nanostars,或 SFGNs 。
" 因此我们开始探究这些金色 nanostars 如何被形成 " ,草莓类植物说。”我们发现 nanostars 有没有表面的功能性正在宁可挑战生产其他化学的程序。我们能控制这些 nanostars 的大小而且表示成核和这些奈米结构的生长的机制的特色。它与形成真正的雪片的机制类似。”
草莓类植物说 graphene 的出现对金色 nanostars 的形成紧要关头。"如果 graphene 缺席,黄金一起会栽成一丛而且安定下来当做大大块, " 他说。”但是 graphene 帮助稳定黄金。这使电子的申请 nanostars 更有用。”
在七月、 Jasuja 和草莓类植物在 ACS-十亿分之一期刊中公开他们的工作。
在 graphene 表演上的这些金色 " 雪片 " 的发现为生物学的装置答应和
电子学。草莓类植物正在附上 DNA 到这些金色岛制造 DNA 感应器。他被 Nihar Mohanty 叁加,电机工程的化学工程,和大学部的研究员 Ashvin Nagaraja 的一位博士的学生,一个年长者。Nagaraja 是一个 2004 曼哈坦中学毕业生。
草莓类植物说 graphene-黄金基础的 DNA 感应器将会提高敏感。用化学减少 graphene 氧化物获得 graphene 需要破坏 DNA 的粗糙的化学药品。
”现在我们能在与黄金一起使插入用金色岛获得 graphene 的 graphene 氧化物上使用粗糙的化学药品。然后我们能使用这些金色岛使起作用 DNA 。”
草莓类植物也正在连同微电波使用 graphene 。他和 Jasuja 正在 " 烹饪 " graphene 床单为另外的一个方法在材料表面上生产粒子。
一些草莓类植物的其他 graphene 研究包括使用被修正的 graphene 床单划分凝结解决,如此稳定它。他的小组最近已经用氢化物减少 graphene 氧化物在数秒的物质中生产缩小的 graphene 氧化物。这样被生产的 graphene 能在解决方面依然稳定好几天。较进一步的结果不久将会在日记中出现很小
只有五年前发现了, graphene 已经引起正在学习它的特别电、机械而且光学的特性的很多研究员的注意,草莓类植物说。他的研究小组在少数的个之中学习材料的表面间特性和生物学的申请。
" 我们正在进入一个新时代 " ,草莓类植物说。"从零-空间或直线的分子或聚合体解决,我们现在正在进入有迷人的新财产的二维的 graphene 解决之内冒险一试. "
