奇异电气性能石墨被确认
电池材料
6人已加入
奇异电气性能石墨被确认
Exotic Electric Properties of Graphene Confirmed
ScienceDaily (Nov. 18, 2009) — First, it was the soccer-ball-shaped molecules dubbed buckyballs. Then it was the cylindrically shaped nanotubes. Now, the hottest new material in physics and nanotechnology is graphene: a remarkably flat molecule made of carbon atoms arranged in hexagonal rings much like molecular chicken wire.
Graphene layers are found in graphite flakes like those from pencil lead. (Credit: Kirill Bolotkin)
Not only is this the thinnest material possible, but it also is 10 times stronger than steel and it conducts electricity better than any other known material at room temperature. These and graphene's other exotic properties have attracted the interest of physicists, who want to study them, and nanotechnologists, who want to exploit them to make novel electrical and mechanical devices.
"There are two features that make graphene exceptional," says Kirill Bolotin, who has just joined the Vanderbilt Department of Physics and Astronomy as an assistant professor. "First, its molecular structure is so resistant to defects that researchers have had to hand-make them to study what effects they have. Second, the electrons that carry electrical charge travel much faster and generally behave as if they have far less mass than they do in ordinary metals or superconductors."
Bolotin has been directly involved in the efforts to manufacture and characterize this exotic new material as a post-doctoral fellow in the laboratory of Philip Kim at Columbia University. In a paper published last week in the journal Nature, he and his Columbia colleagues report that they have managed to clean up graphene enough so that it exhibits a bizarre electrical phenomenon called the fractional quantum Hall effect, where the electrons act together to create new particles with electrical charges that are a fraction that of individual electrons.
Although graphene is the first truly two-dimensional crystalline material that has been discovered, over the years scientists have put considerable thought into how two-dimensional gases and solids should behave. They have also succeeded in creating a close approximation to a two-dimensional electron gas by bonding two slightly different semiconductors together. Electrons are confined to the interface between the two and their motions are restrained to two dimensions. When such a system is cooled down to less than one degree above absolute zero and a strong magnetic field is applied, then the fractional quantum Hall effect appears.
Since scientists figured out how to make graphene five years ago, they have been trying to get it to exhibit this effect with only marginal success. According to Bolotin, the Columbia group figured out that interference from the surface the graphene was sitting on was the problem. So they applied semiconductor lithography techniques to suspend ultraclean graphene sheets between microscopic posts above the surface of semiconductor chips. When they cooled this configuration down within six degrees of absolute zero and applied a magnetic field, the graphene generated a robust quantum Hall effect as predicted by theory.
The best way to understand this counterintuitive effect is to think of the electrons in graphene as a forming a (very thin) sea of charge. When the magnetic field is applied, it generates whirlpools in the electron fluid. Because electrons carry a negative charge, these vortices have a positive charge. They form with fractional charges such as one-third, one-half and two-thirds that of an electron. These positive charge carriers are attracted to and attach to the conduction electrons, creating quasi-particles with fractional charges.
Understanding the electrical properties of graphene is important because, unlike the other materials used by the electronics industry, it remains stable and conductive down to the molecular scale. As a result, when the current silicon technology reaches it's a fundamental miniaturization limit in coming years, graphene could very well take its place.
Meanwhile, some theoretical physicists are interested in graphene for a totally different reason: It provides a new way to test their theories.
As electrons move through ordinary metals, they interact with the electrical fields produced by the lattice of metal atoms, which push and pull them in a complex fashion. The net result is that the electrons act as if they have a mass different from that of ordinary electrons. So physicists call this an "effective mass" and consider them to be quasiparticles. When traveling through graphene they also act as quasiparticles, but they behave as if they have a mass of zero. It turns out that graphene quasiparticles, unlike those in other materials, obey the rules of quantum electrodynamics, the same relativistic equations that physicists use to describe the behavior of particles in black holes and high-energy particle accelerators. As a result, this new material may allow physicists to conduct tabletop experiments that test their theoretical models of some of the most extreme environments in the universe.
The research was supported by grants from Microsoft Project Q, the Defense Advanced Research Project Agency and the Department of Energy.
Graphene 的异国电财产确认
ScienceDaily- (2009 年十一月 18 日)首先,它是足球-配音 buckyballs 的球形的分子。然后它是圆筒形地成形的奈米管。现在,在物理学和纳米技术的最热的新材料是 graphene:一粒显着平坦的以碳制成的分子原子在多像分子的鸡肉电线一样的六角形的戒指中安排了。
Graphene 层在石墨被发现像那些样从铅笔领引剥落。(信用: Kirill Bolotkin)
不只是这最薄的材料可能的,但是它也比钢强壮 10 倍,而且它引导在室温比任何其他的已知材料好的电力。这些而且 graphene 其他异国的特性已经吸引想要学习他们的物理学者的兴趣和 nanotechnologists ,他[她] 想要开发他们制造新奇的电、机械的装置。
" 有两个让 graphene 特别的特征 " , Kirill Bolotin 说,他[她] 才和物理学和天文学的范德比尔特部门成为一个助理教授。”第一,它的分子结构是如此反抗的对缺点哪一研究员已经必须给-使学习的他们成为他们有什么效果。其次,携带电的费用旅行的电子非常快速的而且通常举止好像他们远远地有不如他们在平常的金属或超导体中做得大众的。”
为了在哥伦比亚大学的菲力浦 Kim 的实验室制造并且把这异国的新材料视为一个后博士的人 Bolotin 已经直接地被牵涉。在一张在自然期刊中被公开上星期的纸中,他和他的哥伦比亚同事报告他们已经设法整理 graphene 充足以便它展现一种奇异的电现象─被认为微少分配量是门厅效果,电子行动一起用个别电子是一个分数那的电的费用产生新粒子。
虽然 graphene 是已经被发现的首先真正二维水晶的材料,但是数年以来,科学家把相当多的想法放入二维的瓦斯和固体应该如何举止。他们一起已经也成功地对会接的一种二维电子瓦斯创造一个接近的近似值两个些微不同的半导体。电子盘据二个和他们的运动之间的接口是自制的至两尺寸。当如此的一个系统被冷却降到少于一度在绝对零度上面而且一个强壮的磁场被应用,当时微少分配量门厅效果出现。
自从科学家理解该如何五年前制造 graphene ,他们一直尝试拿用只有边缘的成功展现这一效果的它。依照 Bolotin ,哥伦比亚小组从 graphene 坐下的表面理解那冲突了在是问题之上。因此他们应用了半导体石版印刷术技术在半导体薯条的表面上面在显微镜的职位之间中止 ultraclean graphene 床单。当他们冷却了在绝对零度的六度里面下降的这一个结构,而且应用了一个磁场, graphene 产生了强健分配量门厅如理论所预测的效果。
了解这反直觉的效果最好的方式为在 graphene 中想到电子当做一形成费用的海洋(非常瘦的)。当磁场被应用,它在电子液体中产生漩涡。因为电子传达一项否定的费用,这些旋涡有一个阳电荷。他们以微少的费用形成如此的当做三分之一,一-一半和三分之二电子的。这些个阳电荷运送者对传导电子被吸引到而且附上,创造似乎是粒子的与微少的费用。
理解 graphene 的电财产很重要因为,不像被电子学业用的其他材料,它对分子的刻度依然稳定、传导性向下。结果,当现在的矽技术到达它在未来的数年中是一个基本的小型化界限, graphene 会非常涌出取代它。
同时,一些理论上的物理学者因为完全不同的理由对 graphene 感兴趣:它提供一个新方法测试他们的理论。
因为电子移动过平常的金属,他们与被金属制原子的格子生产的电场互动,推而且在一种复杂的流行中拉他们。净结果是电子行动好像他们平常电子的那让块不同的。因此物理学者认为这是 " 有效的块 " 而且考虑他们是 quasiparticles 。当旅行过 graphene 他们也担任 quasiparticles ,但是他们举止好像他们有大量的零。它把 graphene quasiparticles ,不像在其他材料的那些,服从分配量电气力学的规则关掉,相同的相对主义的相等物理学者使用在黑色洞描述粒子的行为和高能源粒子加速者。结果,这新材料可能让物理学者引导测试他们的一些宇宙中最极端的环境的理论上模型的桌上用的实验。
研究由授与从微软计画 Q 所支援了,前进研究计画代理商和能源部的防卫。
  • 相关推荐
  • 热点推荐
  • 石墨
