接插件
连接器英文专业类术语
冲压类
punch, press冲
punching machine 冲床
hydraulic machine油压机
jack升降机
decoiler整平机
manufacture management製造管理
stamping, press冲压
feeder送料机
rack, shelf, stack料架
taker取料机
to reverse material 翻料
to load material上料
to unload material卸料
to return material/stock to退料
scraped |’skr鎝id|报废
scrape ..v.刮;削
robot机械手
production line流水线
packaging tool打包机
packaging打包
成型类
well type蓄料井
insulated runner绝缘浇道方式
hot runner热浇道
runner plat浇道模块
valve gate阀门浇口
band heater环带状的电热器
spindle阀针
spear head鉋尖头
slag well冷料井
cold slag冷料渣
air vent排气道
welding line熔合痕
eject pin顶出针
knock pin顶出销
return pin回位销反顶针
sleeve套筒
stripper plate脱料板
insert core放置入子
runner stripper plate浇道脱料板
guide pin导销
eject rod (bar)(成型机)顶业捧
subzero深冷处理
three plate三极式模具
runner system浇道系统
stress crack应力电裂
orientation定向
sprue gate射料浇口,直浇口
nozzle射嘴
sprue lock pin料头鉤销(拉料杆)
slag well冷料井
side gate侧浇口
edge gate侧缘浇口
tab gate搭接浇口
film gate薄膜浇口
flash gate闸门浇口
slit gate缝隙浇口
fan gate扇形浇口
dish gate因盘形浇口
diaphragm gate隔膜浇口
ring gate环形浇口
submarine gate潜入式浇口
tunnel gate隧道式浇口
pin gate针点浇口
runner less无浇道
sprue less 无射料管方式
long nozzle延长喷嘴方式
spur浇口;溶
waste废料
board看板
sliding rack滑料架
to impose lines压线
to compress, compressing压缩
character die字模
to feed, feeding送料
material change, stock change材料变更
feature change 特性变更
prepare for, make preparations for 准备
rotating speed, revolution转速
abnormal handling异常处理
组装类
Assembly line组装线
Layout布置图
Conveyer流水线运输带
Rivet machine拉钉机
Rivet gun拉钉枪
Screw driver起子
Electric screw driver电动起子
Hydraulic machine 液压机
Pneumatic screw driver气动起子
automation自动化
to stake, staking, riveting铆合
add lubricant oil加润滑油
argon welding氬焊
cylinder油缸
robot机械手
conveying belt输送带
transmission rack输送架
to draw holes抽孔
bolt螺栓
nut 螺母
screw 螺丝
identification tag标示单
screwdriver plug起子插座
automatic screwdriver电动启子
to move, to carry, to handle搬运
be put in storage入库
packing包装
staker = riveting machine铆合机
