手动删除python导致的问题如何解决?
情况说明
在ubuntu server 20.02下安装了python 2.7, 3.8.5, 3.9。python默认被设置在3.8.5下, 3.9是之前为了验证问题安装的,现在并没有在使用。
当我安装pyserial包的时候,发现这台server并没有安装pip,于是安装pip:
sudo apt-get install python3-pip
再安装pyserial包
sudo pip3 install pyserial
此时在python下import serial会提示找不到包,检查发现默认运行的是python 3.8.5,但是pyserial被安装在python3.9下面。由于所有的脚本都是跑在3.8.5下,因此希望pyserial也安装到3.8.5下,卸载没有使用的python3.9:
sudo pip3 uninstall pyserial
sudo apt-get --purge remove python3-pip
sudo apt-get --purge remove python3.9
此时为python 3.8.5安装pip3和pyserial,发现还是被装在/user/lib/python3.9下面,在/usr执行下面命令
find -name python3.9*
发现python3.9并没有清除干净
。/bin/python3.9
。/lib/python3.9
。/share/man/man1/python3.9.1.gz
。/share/binfmts/python3.9
。/share/doc/python3.9-doc
。/share/doc/python3.9/html/python3.9.devhelp.gz
。/share/doc/python3.9-minimal
。/share/doc-base/python3.9-lib
。/share/doc-base/python3.9-inst
。/share/doc-base/python3.9-api
。/share/doc-base/python3.9-tut
。/share/doc-base/python3.9-new
。/share/doc-base/python3.9-ext
。/share/doc-base/python3.9-dist
。/share/doc-base/python3.9-ref
。/share/lintian/overrides/python3.9-doc
。/share/lintian/overrides/python3.9-minimal
。/share/devhelp/books/python3.9
。/share/info/python3.9.info.gz
。/include/python3.9
。/include/x86_64-linux-gnu/python3.9
。/include/x86_64-linux-gnu/python3.9d
。/include/python3.9d
于是手动删除
1
find -name python3.9* | xargs sudo rm -rf
然后噩梦开始,此时再安装pip3,会提示已经安装
/usr$ sudo apt-get install python3-pip
Reading package lists.。。 Done
Building dependency tree
Reading state information.。。 Done
python3-pip is already the newest version (20.0.2-5ubuntu1.5)。
0 upgraded, 0 newly installed, 0 to remove and 57 not upgraded.
但执行pip,又会说找不到
/usr$ sudo pip3 install pyserial
sudo: unable to execute /usr/bin/pip3: No such file or directory
如果再次卸载pip3, 提示错误
Removing python3-pip (20.0.2-5ubuntu1.5) 。。。
/var/lib/dpkg/info/python3-pip.prerm: 6: py3clean: not found
dpkg: error processing package python3-pip (--remove):
installed python3-pip package pre-removal script subprocess returned error exit status 127
dpkg: too many errors, stopping
/var/lib/dpkg/info/python3-pip.postinst: 6: py3compile: not found
dpkg: error while cleaning up:
installed python3-pip package post-installation script subprocess returned error exit status 127
Errors were encountered while processing:
python3-pip
Processing was halted because there were too many errors.
E: Sub-process /usr/bin/dpkg returned an error code (1)
解决方法
sudo apt-get update
sudo apt-get upgrade
sudo apt --fix-broken install
dpkg --configure -a
apt-get download python3-minimal
sudo dpkg -i *python3*.deb
sudo apt-get -f install
编辑:jq
  • 相关推荐
  • 热点推荐
  • p
