DC2120A, Demonstration Board using LT3048 Low Noise Bias Generator, Boost DC/DC Converter with integrated Schottky diode and LDO in a 2mm + 2mm DFN package. This demo board is designed to convert a 2.7V to 4.8V input to a 15V output at 19mA to 35mA with low output ripple and noise. The LT3048-15 is programmed for 2MHz switching frequency. This demonstration board can be used to evaluate other fixed output voltage versions of the LT3048
