DC616B DC616B评估板
KANA 发表于 2021-07-31 13:00:03
数据:
dc616b DC616B LTC3425EUH | 4MHz, Polyphase, 2V to 3VIN, 2 Circuits, 5VOUT1 @ 2A, 5VOUT2 @ 1.5A Demonstration Circuit 616 is a synchronous, 4-phase boost converter using the LTC3425. It is capable of operating below 1V input. DC616A is set for 3.3V output. DC616B is set for 5V output. On each demo board, the left circuit gives higher efficiency and current rating; while the right circuit has smaller size and lower cost. The switching frequency is set at 1MHz per phase, minimizing inductor and capacitor size. A single resistor at RT pin sets the frequency. If desired, the LTC3425 can be synchronized to an external clock. DC616B
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
