DC414B DC414B评估板
KANA 发表于 2021-07-30 11:00:02
数据:
dc414b DC414B LTC1871EMS | Boost Controller, 3V ≤ VIN ≤ 5V, VOUT = 5V @ 7A Demonstration circuit DC414 is a step-up (Boost) DC-DC converter featuring the LTC1871 controller. The circuit is capable of providing an output voltage of 5V at 7A (10A peak) from an input supply of 3.3V. External frequency synchronization is provided, as are two modes of operation at light load conditions: Burst mode™ operation to reduce switching losses and maintain high operating efficiency, and continuous mode to provide constant operating frequency with low quiescent current. The LTC1871 is a No RSENSE™ current mode step-up controller. It eliminates the need for a current sense resistor and maximizes the efficiency of the demo circuit —up to 95%. The LTC1871 can operate up to a frequency of 1MHz, allowing for the use of small inductors and capacitors. The low shutdown quiescent current of 10μA makes the LTC1871 ideally suited for battery-operated systems. Applications include telecom power supplies, cellular phones, PDAs and portable electronic equipment.   DC414B
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
