DC524A DC524A评估板
KANA 发表于 2021-07-31 01:00:01
数据:
dc524a DC524A LTC3704EMS Demo Board | Positive to Negative Converter, 5V to 15VIN, –5.2VOUT @ 2.5A Demonstration circuit 524 is a positive input to negative output converter featuring the LTC3704 switching controller. The DC524 converts a 5V to 15V input to a –5.2V output and provides up to 2.5A of output current from 5V input. The converter operates at 300kHz with a high efficiency of 89%. The DC524 is set to operate in No RSENSE™ mode with input voltages up to 15V. However, DC524 can be modified for higher input voltages with an optional current sense resistor. The circuit features optional soft-start circuitry that can be enabled or disabled with a single jumper. Also, DC524 has a jumper to program either continuous or Burst Mode™ operation. The DC524 can be synchronized to an external clock of up to 400kHz. DC524A
技术文档
数据手册(0)
