ChipProg+主要特性
ChipProg+ is a small universal programmer which supports virtually all 8051 programmable microcontrollers from Atmel, Atmel W&M, Dallas, Hynix, Intel, ISSI, Philips, SST, and Winbond. Many other microcontrollers are also supported.
Major Features
- Supports about 3000 devices and new targets are always in development
- Supports popular embedded microcontrollers with internal memory from Atmel, Atmel W&M, Dallas Semiconductor, Hynix, Infineon, Intel, ISSI, Microchip, Mitsubishi, National Semiconductor, Philips, SST, STMicroelectronics, Winbond, XEMICS, Zilog and others
- Supports almost all popular Flash, OTP, MTP, UV-erasable serial and parallel non-volatile memory chips that includes generic parallel EPROM, EEPROM and Flash memories, serial EPROM from Altera, AMD, Atmel, Catalyst, Exel, Futjitsu, Hitachi, Holtek, Hynix, Intel, ISSI, Macronix, Microchip, Micron, Mitsubishi, Mosel-Vitelic, National Semiconductors, NEC, OKI, Philips, PMC, Ricoh, Samsung, Sharp, SST, STMicroelectronics, Texas Instruments, Toshiba, VLSI, Winbond, Xicor, Xilinx and others
- Supports many popular programmable logical devices (PAL, GAL, EPLD) from Altera, Atmel, Cypress, ICT, Lattice, Vantis, and Xilinx
- 40-pin ZIF DIP socket for all DIP devices
- Optional adapters for PLCC, SOIC, QFP, TSOP, SSOP and BGA packages
- Compatible with many third-party adapters
- Standard parallel port interface to a personal computer
- Advanced self-diagnostic test routine
- Loads files in Binary, Intel extended HEX, Motorola S-Record and Tektronix HEX formats
- Full screen multi-buffer editor
- Fine Vpp setting for burning hard-to-program samples and obsolete devices
- Allows operations in buffers with Hexadecimal, Binary, Decimal, ASCII dumps and files
- Allows advanced block operations: marking, copying, moving, filling with symbols, searching, etc.
- Checksum automatic calculation
- Hot keys for frequently used commands: Blank Check, Erase, Read, Write, Verify, Lock
- Operations in boot blocks of flash devices (where applicable)
- Incorrect device insertion check
- Embedded C-like script language for automated programming and custom commands
- Small and convenient - only 6" x 3" x 1" or 150 x 90 x 25 mm size
- Lifetime free software update via the http://www.phyton.com website
