DC2341A DC2341A评估板
KANA 发表于 2021-08-04 09:00:02
数据:
dc2341a DC2341A LTC7130EY Demo Board | Monolithic 20A Buck with mΩ DCR Sensing; 4.5V ≤ VIN ≤ 20V, VOUT = 1.5V @ 20A Demonstration circuit 2341A is a high efficiency synchronous buck DC/DC converter with 4.5V to 20V input range. It can supply 20A maximum load current at 1.5V output. The demo board features the LTC7130 regulator. No external MOSFETs are required. It employs an LTC proprietary current sensing, current mode architecture, allowing the use of a very low DC resistance (DCR) power inductor to maximize efficiency in high current applications. Differential output voltage sensing along with a precision internal reference combine to offer accurate output regulation. The LTC7130 is housed in a 6.25mm × 7.5mm × 2.22mm 63-pin BGA package. DC2341A
技术文档
数据手册(0)
