DC2157A DC2157A评估板
KANA 发表于 2021-08-03 15:00:03
数据:
dc2157a DC2157A LTM4630EY-1 Demo Board | Dual 18A/Single 36A Buck μModule Regulator, 4.5V ≤ VIN ≤ 15V, VOUT1 = 1.5V @ 18A, VOUT2 = 1V @ 18A Demonstration circuit 2157A features the LTM4630EY-1, the high efficiency, high density, dual 18A, switch mode step-down power module regulator with ±0.8% total DC output accuracy. The input voltage is from 4.5V to 15V. The output voltage is programmable from 0.6V to 1.8V. DC2157A can deliver up to 18A maximum in each channel. With the help of external compensation, ±3% transient accuracy can be achieved with 25% load step. As explained in the data sheet, output current derating is necessary for certain VIN, VOUT, and thermal conditions. The board operates in continuous conduction mode in heavy load conditions. For high efficiency at low load currents, the MODE jumper (JP1) selects pulse-skipping mode for noise sensitive applications or Burst Mode® operation in less noise sensitive applications. Two outputs can be connected in parallel for a single 36A output solution with optional jumper resistors.   DC2157A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
