DC2131A DC2131A评估板
KANA 发表于 2021-08-03 16:00:03
数据:
dc2131a DC2131A LTC3623 Demo Board | Silent Switcher Sync Buck, 4V ≤ VIN ≤ 15V, VOUT = 1V/1.5V/2.5V/3.3V/5V @ ±5A Demonstration circuit 2131A is a current mode DC/DC step-down Silent Switcher® buck regulator featuring the LTC3623. The board operates from an input range of 4V to 15V, and provides ±5A of output current. The output voltage of the demonstration board can be set from 0V to VIN – 0.5V. It operates at 1MHz and may be synchronized to an external clock. A soft-start feature controls output voltage slew rate at start-up, reducing current surge and voltage overshoot. A power good output and current monitor signal are provided. Discontinuous conduction mode can be selected with a jumper. The demonstration board has options for cable drop compensation, negative output voltage and input voltage regulation. DC2131A
技术文档
数据手册(0)
