AIC1187的特性及应用电路
稳压电源
160人已加入
AIC1187的特性及应用电路
1A Ultra Low Dropout Linear Regulator
FEATURES
Guaranteed 1A Output Current.
Low Ground Current
Wide Operating Voltage Ranges: 2.3V to 5.5V.
0.5?A Quiescent Current in Shutdown.
Fixed Output Voltage of 1.5V, 1.8V, 2.5V, 3.3V
Fast Transient Response
Current Limit and Thermal Limit
Available in SOT-223, TO-220, TO-263, TO-263-5, TO-252 and TO-252-5 Packages
APPLICATIONS
Mother Board and Notebook
Gigabit Ethernet Switch
Microprocessor Power Systems
Network Cards
Peripheral Cards
GTL, GTL+, BTL, and SSTL Bus Terminators
DSPs Power Supplies
Battery Powered Applications
DESCRIPTION
The AIC1187 is an ultra low dropout and high performance linear regulator with 1A output current capability. The output voltage is fixed 1.5V, 1.8V, 2.5V and 3.3V. Its low dropout voltage and fast transient response make it ideal for low voltage microprocessor applications.
In addition, the enable pin reduces power dissipation at shutdown mode. Current limit and thermal protection provide protection against any overload condition that would create excessive junction temperatures.
TYPICAL APPLICATION
AIC1187,pdf,datasheet
  • 相关推荐
  • 热点推荐
