AIC1190的特性及应用
稳压电源
160人已加入
AIC1190的特性及应用
Ultra LDO 1A Linear Regulator With Adjustable & Bypass Pin
FEATURES
Guaranteed 1A Output Current.
Fast Response in Line/Load Transient
Wide Operating Voltage Ranges: 2.3V to 6.0V.
<0.1?A Shutdown Standby Current
Low Quiescent Current: < 60?A.
Fixed: 1.2V, 1.5V, 1.8V, 2.0V, 2.5V, 2.7V, 3.0V, 3.3V, 3.5V, 3.7V, 3.8V Output Voltage.
Adjustable Output Voltage are available from 0.8~4.5V
Low Dropout?440mV at 1A and 2.8V output voltage.
High PSRR?70dB at 1KHz.
Active Low or High Shutdown Control. Current Limit and Thermal rotection.
Available in ∮2% Output Tolerance.
Available in SOT-223 & TO-220 (3 pin) & SOP-8 Exposed Pad (Heat Sink) and TO-252 &TO-263 (3 & 5 pin) Package.
APPLICATIONS
Motherboard USB Management.
USB Power Management.
Hot Plug-In Power Supplies.
Battery-Charger Circuit.
Power Distribution Switch.
DESCRIPTION
A low noise, high PSRR and ultra low dropout linear regulator AIC1190 is optimized for low ESR ceramic capacitors operation with 1A continuous current. The AIC1190 is designed for portable and wireless devices with demanding performance and space requirements.
The AIC1190 offers high precision output voltage of ∮2% tolerance. Output voltage can also be adjusted for those other than the preset values.
A noise bypass pin is available for further reduction of output noise. The bypass pin could be floating if itˇs unnecessary. At 1A load current and 2.8V output voltage, a 440mV dropout is performed. The quality of low quiescent current and low dropout voltage makes this device ideal for battery power applications. The high ripple rejection and low noise of the AIC1190 provide enhanced performances for critical applications such as cellular phones, and PDAs.
In addition, a logic-level shutdown input is included, which reduce supply current to less than 0.1?A (typ.) in shutdown mode with fast turn-on time less than 100?s. The AIC1190ˇs current limit and thermal protection provide protection against any overload condition that would create excessive junction temperatures.
TYPICAL APPLICATION
AIC
AIC1190 datasheet,pdf
  • 相关推荐
  • 热点推荐
  • AIC
