DC2011A DC2011A评估板
KANA 发表于 2021-08-05 21:00:04
数据:
dc2011a DC2011A Demonstration Circuit 2011A is a 42V, 6A micropower synchronous step-down regulator with current sense featuring the LT8613. The demo board is designed for 5V output from a 5.8V to 42V input. The wide input range allows a variety of input sources, such as automotive batteries and industrial supplies. The LT8613 is a compact, high efficiency, and high speed synchronous monolithic step-down switching regulator. The integrated power switches and inclusion of all necessary circuitry reduce the components count and solution size. Ultralow 3μA quiescent current in Burst Mode® operation achieves high efficiency at very light loads. Fast minimum on-time of 40ns enables high VIN to low VOUT conversion at high frequency. LT8613EUDE Demo Board | Sync Buck, 5.8V ≤ VIN ≤ 42V, VOUT = 5V @ 6A DC2011A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
