DC1973A DC1973A评估板
KANA 发表于 2021-08-05 12:00:03
数据:
dc1973a DC1973A LT8697 Demo Board | 6V ≤ VIN ≤ 42V, 5V @ 2.5A USB Supply Output, Cable Drop Compensation Demonstration circuit 1973A is a USB 5V 2.5A output, 6V to 42V input synchronous buck with cable drop compensation featuring the LT8697. The LT8697 is a compact, high efficiency, high speed synchronous monolithic step-down switching regulator designed to power 5V USB applications. A precise output voltage and programmable cable drop compensation maintain accurate 5V regulation at the USB socket at the end of a long cable. The circuit runs at 2MHz to minimize external components size and to avoid AM band. DC1973A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
