DC1893A DC1893A评估板
KANA 发表于 2021-08-05 20:00:03
数据:
dc1893a DC1893A LT3697EMSE Demo Board | 8V ≤ VIN ≤ 35V; VOUT = 5V at 2.4A Demonstration circuit 1893A is a USB 5V, 2.4A output, 35V input buck with cable drop compensation featuring the LT3697. The LT3697 is a step-down switching regulator designed to power 5V USB applications. A precise output voltage and programmable cable drop compensation maintain accurate 5V regulation at the USB socket at the end of a long cable. The circuit was designed to run at 500kHz to avoid the AM band. The demo board has an EMI filter installed. The radiated EMI performance of the board is on Figures 3 to 5, showing the circuit passes CISPR25 Class 5 with a wide margin. DC1893A
技术文档
数据手册(0)
