DC1936A DC1936A评估板
KANA 发表于 2021-08-05 13:00:03
数据:
dc1936a DC1936A LTC3882EUJ Demo Board | Dual Buck Voltage Mode Controller with PSM, 7V ≤ VIN ≤ 14V; 0.8V ≤ VOUT0 ≤ 1.8V @ 30A, 0.8V ≤ VOUT1 ≤ 1.8V @ 30A Demonstration circuit 1936A is a high current, high efficiency, polyphase synchronous buck converter featuring the LTC3882EUJ, a dual output polyphase voltage mode controller. The LTC3882 has the PMBus interface and power system management functions. The DC1936A uses 6mm × 6mm DrMOS as the power stage. The input range of this board is from 7V to 14V, and the output voltage can be programmed from 0.8V to 1.8V. The DC1936A provides two outputs, with each output capable of 1V/30A. The DC1936A has optional discrete driver (LTC4449EDCB) and MOSFET footprints for high input voltage applications up to 38V. The DC1936A also has an on-board dynamic load circuit, which makes it easy for the customer to evaluate the transient performances. DC1936A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
