SN75LVCP412A应用电路
稳压电源
160人已加入
SN75LVCP412A应用电路
Two Channel SATA 3-Gbps Redriver
DEVICE IMPLEMENTATION     SN75LVCP412A datasheet,pdf
SN75LVCP41
A. Place supply capacitors close to the pin.
B. EN can be left open or tied to supply when no external control is implemented.
C. Output pre-emphasis (PE1, PE2) is shown enabled. Setting depends on device palcement relative to eSATA connector.
