DC1484A-A DC1484A-A评估板
KANA 发表于 2021-08-11 09:00:03
数据:
dc1484a-a DC1484A-A LT3651EUHE-8.4 Demo Board | 12V to 32VIN, 4A Synchronous Buck 2-Cell Li-Ion Charger Demonstration circuit 1484A-A is a 4A high voltage 2-Cell Li-Ion battery charger featuring the LT3651EUHE-8.4. The LT3651 is a complete, high power Li-Ion battery charger that can operate over a wide input voltage range. The charger is a constant-current, constant-voltage type with a maximum charge current of 4A that can be externally set. A precondition feature trickle charges a low voltage battery and bad battery detection provides a signal if the battery doesn’t respond to preconditioning. DC1484A-A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
