DC1411A DC1411A评估板
KANA 发表于 2021-08-11 07:00:02
数据:
dc1411a DC1411A LTC3787EUFD Demo Board | 5V to 24VIN to 24VOUT at 6A Demonstration circuit DC1411 is DC/DC boost converter featuring the LTC3787 constant frequency current mode boost controller. The DC1411A operates over 5V to 24V input and provides 6A to 16A of output current. The 350kHz constant frequency operation results in small and efficient circuit. The converter provides high output voltage accuracy (typically ±3%) over wide load range with no minimum load requirement. The demonstration circuit can be easily modified to generate different output voltages. DC1411A
技术文档
数据手册(0)
