DC1479A DC1479A评估板
KANA 发表于 2021-08-10 12:00:03
数据:
dc1479a DC1479A LTC3865EUH Demo Board | 4.5V ≤ VIN ≤ 14V, VOUT1 = 1.5V @ 15A, VOUT2 = 1.2V @ 15A Demonstration circuit 1479A is a dual output synchronous buck DC/DC converter featuring the LTC3865EUH. The input voltage range is from 4.5V to 14V. The outputs are 1.5V/15A and 1.2V/15A. Each output voltage can be precisely programmed to a preset value within 1% error using two 3-state programming pins. The output voltage can be set to 1.0V, 1.1V, 1.2V, 1.5V, 1.8V, 2.5V 3.3V or 5V. The LTC3865 differs from the LTC3865-1 in that the "-1" has a fixed current limit threshold. The 32-pin package options for both devices have no SGND pin and only one PGND pin. DC1479A
技术文档
数据手册(0)
