DC1405A DC1405A评估板
KANA 发表于 2021-08-10 14:00:03
数据:
dc1405a DC1405A LT3492EFE Demo Board | Boost/Buck-Boost Triple Output LED Driver, 8V ≤ VIN ≤ 40V, VLED = 54V @ 61mA (x3) Demonstration circuit 1405 is a Triple Boost or Buck/Boost LED Driver featuring the LT3492. The LT3492 is a triple output DC/DC converter designed to operate as current sources for driving LEDs using . Each of the three regulators on the demo board is independently operated. The board can be configured with either boost (default) or buck-boost mode; buck mode is not supported. The current for each output is 61mA in either mode. The IC's input voltage range is 8V to 30V with 40V transient protection; however the LEDs input power source can be as high as 40V.  The overvoltage protection (open LED detect) is set at 58V. For a typical application with a LED voltage of 3.6V, each boost circuit can drive around 15 LEDs. Applications with different input voltages and load combinations can be demonstrated on this circuit with some board modifications.    DC1405A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
