DC1180A DC1180A评估板
KANA 发表于 2021-08-12 14:00:03
数据:
dc1180a DC1180A LTC3407AEDD Demo Board | (DFN) 2.5 ≤ VIN ≤ 5.5V, VOUT1 = 1.2V/1.5V/1.8V @ 0.6A, VOUT2 = 2.5V/3.3V @ 0.6A Demonstration circuit DC1180 is a dual output regulator consisting of two identical constant frequency step-down converters, based on the LTC3407A monolithic dual synchronous buck regulator in the 3 × 3 DFN-10 package. The LTC3407A is similar to the LTC3407 but has a lower ripple Burst Mode operation and includes an optional external soft-start. The DC1180 has an input voltage range of 2.5V to 5.5V, and either output is capable of delivering up to 600mA of output current. In Burst Mode® operation, the DC supply current is typically only 25 µA (per channel) at no load, and less than 1 µA in shutdown. The DC1180 is a very efficient circuit: up to 96% for either circuit. DC1180A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
