DC1897B DC1897B评估板
KANA 发表于 2021-08-13 11:00:03
数据:
dc1897b DC1897B LTC3605A Demo Board | 4V to 20V Input, VOUT = 2.5V/3.3V/5V/Adj at 5A Demonstration circuit 1897 is a step-down converter, using the LTC3605A monolithic synchronous buck regulator. The DC1897B has a maximum input voltage of 20V, and is capable of delivering up to 5A of output current at a minimum input voltage of 4V. The output voltage of the DC1897B can be set as low as 0.6V, the reference voltage of the LTC3605A. It has a jumper that allows the output to be set at 2.5V, 3.3V or 5V. The LTC3605A has a phase-lock-loop circuit, allowing high current multiphase operation of several DC1897Bs in parallel.
DC1897B
技术文档
数据手册(0)
