DC1608A DC1608A评估板
KANA 发表于 2021-08-13 12:00:02
数据:
dc1608a DC1608A LT3745 Demo Board | Three 16-Channel Buck RGB LED Drivers, Requires DC590B, 9V ≤ VIN ≤ 40V, VLED = 3.4V or 4.2V @ 50mA per Channel Demonstration circuit 1608A features the LT3745, a 16-channel 50mA buck LED driver controller and serial interface. Each channel drives a single LED. Three LT3745's are connected in series with each one controlling a color in a 16 LED RGD array. Each channel has an individually adjustable 12-bit (4096-step) grayscale PWM dimming control and a 6-bit (64-step) dot correction current adjustment. The demo board input voltage range is 9V to 40V and the buck controller outputs 3.4V or 4.2V depending on the color of the LED. DC1608A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
