DC1038A-C DC1038A-C评估板
KANA 发表于 2021-08-13 16:00:03
数据:
dc1038a-c DC1038A-C LT3837EFE | 9V to 36V input to 12V at 3A Synchronous Flyback Converter Demonstration circuit 1038A-C is a 36W isolated flyback converter with synchronous rectification and primary-side regulation featuring the LT3837. This circuit was designed to demonstrate the high levels of performance, efficiency, and small solution size attainable using the part in a flyback power supply. It operates at 200kHz and produces a regulated 12V, 3A output from an input voltage range of 9V to 36V. Isolation voltage is 1500VDC. DC1038A-C
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
