DC1038A-A DC1038A-A评估板
KANA 发表于 2021-08-13 16:00:03
数据:
dc1038a-a DC1038A-A LT3837EFE | 9V to 36V input to 3.3V at 10A Synchronous Flyback Converter Demonstration circuit 1038A-A is a 33W isolated flyback converter with synchronous rectification and primary-side regulation featuring the LT3837. This circuit was designed to demonstrate the high levels of performance, efficiency, and small solution size attainable using the part in a flyback power supply. It operates at 200kHz and produces a regulated 3.3V, 10A output from an input voltage range of 9V to 36V. Isolation voltage is 1500VDC. DC1038A-A
技术文档
数据手册(0)
