DC1038A-B DC1038A-B评估板
KANA 发表于 2021-08-13 17:00:03
数据:
dc1038a-b DC1038A-B LT3837EFE | 9V to 36V input to 5V at 7A Synchronous Flyback Converter Demonstration circuit 1038A-B is a 35W isolated flyback converter with synchronous rectification and primary-side regulation featuring the LT3837. This circuit was designed to demonstrate the high levels of performance, efficiency, and small solution size attainable using the part in a flyback power supply. It operates at 200kHz and produces a regulated 5V, 7A output from an input voltage range of 9V to 36V. Isolation voltage is 1500VDC. DC1038A-B
技术文档
数据手册(0)
