继电器与开关电路
固态继电器开关电路,Solid state relay switch
Description
Solid State Relay Switch is a simple kit which will help you control (ON / OFF) a single high power circuit from a low power drive.
Load - 24 to 240 VAC @ 500 W
Trigger voltage - 2 to 5 VDC (TTL) @ 10 mA
Input isolated with use of Optocoupler
Power Battery Terminal (PBT) for easy input 230 VAC mains and load connection
Terminal pins for connecting input trigger signal
Heatsink for TRIAC
Four mounting holes of 3.2 mm each
PCB dimensions 29 mm x 74 mm
Schematic
