DC2314A-A DC2314A-A评估板
KANA 发表于 2021-08-18 10:00:02
数据:
dc2314a-a DC2314A-A LTC4236-1 Demo Board | Dual Ideal Diode-OR & Single Hot Swap Controller with Current Monitor, Latch-Off Version Demonstration circuit 2314A is intended to demonstrate the performance of the LTC4236-1/LTC4236-2 Dual Ideal Diode-OR and Single Hot Swap Controller with Current Monitor. The controller operates in redundant supply circuits, where each rail has an individual ideal diode, and the outputs are connected to the load through a single Hot Swap circuit. The controller enables monitoring of the load current by providing a signal that is 100× the sense resistor voltage. DC2314A-A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
