路由器
CISCO路由器初始配置手册
很多初学路由器知识的网友对路由器的初始配置可能感到很陌生,本人在初学时也很困惑,因为一下出来很多提问不知如何是好,下面将最近刚调试的一台CISCO3640的初始配置整理出来与各位网友交流,如有疏漏之处,还请大家指正。
1.用CISCO随机带CONSOLE线,一端连在CISCO路由器的CONSOLE口,一端连在计算机的COM口。
2.打开电脑,启动超级终端.为您的连接取个名字,比如CISCO_SETUP,下一步选定连接时用COM1,下一步选定第秒位数9600,数据位8,奇偶校验无,停止位1,数据流控制无.最后选确定。
3.打开路由器电源,这时超级终端将出现以下画面:
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.C3600 processor with 32768 Kbytes of main memory Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0x4ed478 Self decompressing the image :
[OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3640-I-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 12:26 by ccai
Image text-base: 0x600088F0, data-base: 0x60924000
cisco 3640 (R4700) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID 25125768
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: y
您是否进入初始化配置对话,选Y
At any point you may enter a question mark '?' for help.
Use ctrl-c to abort configuration dialog at any prompt.
Default settings are in square brackets '[]'.Basic management setup configures
only enough connectivity
for management of the system, extended setup will ask you
to configure each interface on the system
Would you like to enter basic management setup? [yes/no]: n
您是否进入基本配置安装,选N
First, would you like to see the current interface summary? [yes]: y
首先,您是否看一下当前端口状态
Any interface listed with OK? value "NO" does not have a valid configuration
Interface IP-Address OK? Method Status Protocol
FastEthernet0/0unassigned NO unset up down
Serial0/0 unassigned NO unset down down
FastEthernet0/1unassigned NO unset up down
Configuring global parameters:
Enter host name [Router]:RouterA
输入路由器的名字
The enable secret is a password used to protect access to
privileged EXEC and configuration modes. This password, after
entered, becomes encrypted in the configuration.
Enter enable secret: aaa
输入密文
The enable password is used when you do not specify an
enable secret password, with some older software versions, and
some boot images.
Enter enable password: bbb
输入密码(不能和密文相同)
The virtual terminal password is used to protect
access to the router over a network interface.
Enter virtual terminal password: ccc
输入虚拟终端的密码(以备远程登录)
Configure SNMP Network Management? [yes]: n
配置简单网管吗?选N
Configure IP? [yes]: y
配置IP吗?选Y
Configure IGRP routing? [yes]: n
配置IGRP路由选择协议吗?选N
Configure RIP routing? [no]:
配置IGRP路由选择协议吗?选N
Configure bridging? [no]:
配置桥接吗?选N
Async lines accept incoming modems calls. If you will have
users dialing in via modems, configure these lines.
Configure Async lines? [yes]: n
配置异步线路吗?选N
Configuring interface parameters:
Do you want to configure FastEthernet0/0 interface? [yes]: y
您是否想配置fastethernet0/0接口?选Y
Use the 100 Base-TX (RJ-45) connector? [yes]: y
用RJ45的连接器吗?选Y
Operate in full-duplex mode? [no]: y
选用全双工模式?选Y
Configure IP on this interface? [yes]: y
在这个接口上配置IP吗?选Y
IP address for this interface: 192.168.0.1
配置该接口的IP地址(在此地址为192.168.0.1
Subnet mask for this interface [255.255.255.0] :
配置该接口的子网掩码.(默认的是255.255.255.0,可以手工输入修改)
Class C network is 192.168.0.0, 24 subnet bits; mask is /24
Do you want to configure Serial0/0 interface? [yes]: y
您想配置serial0/0接口吗?选Y
Some supported encapsulations are
ppp/hdlc/frame-relay/lapb/x25/atm-dxi/smds
Choose encapsulation type [hdlc]:
选择封装方式(默认的封装方式是HDLC,您可根据与您的路由器相连选用的封装类型来决
定用什么样的封装类型
No serial cable seen.
Choose mode from (dce/dte) [dte]:
(因为没有连串口线所以会让您选择设备类型)
(在接口上配置IP)
Configure IP unnumbered on this interface? [no]:
IP address for this interface: 172.16.0.5
配置该接口的IP地址(在此地址为172.16.0.5)
Subnet mask for this interface [255.255.0.0] : 255.255.255.252
配置该接口的子网掩码.(默认的是255.255.0.0,可以手工输入修改为255.255.255.252)
Class B network is 172.16.0.0, 30 subnet bits; mask is /30
(以下配置同上)
Do you want to configure FastEthernet0/1 interface? [yes]:
IP address for this interface: 172.16.0.9
Subnet mask for this interface [255.255.0.0] : 255.255.255.252 Class B network is 172.16.0.0, 30 subnet bits; mask is /30
The following configuration command script was created:
(把您的配置显示出来)
hostname aaa
enable secret 5 $1$ul/V$ezbZFgvzGHD.YPSieC0Ew/
enable password RouterA
line vty 0 4
password ccc
no snmp-server
ip routing
no bridge 1
interface FastEthernet0/0
media-type 100BaseX
full-duplex
ip address 192.168.0.1 255.255.255.0
interface Serial0/0
encapsulation hdlc
ip address 172.16.0.5 255.255.255.252
interface FastEthernet0/1
media-type 100BaseX
full-duplex
ip address 172.16.0.9 255.255.255.252
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
end
以下提示您是否保存这次设置
[0] Go to the IOS command prompt without saving this config.
[1] Return back to the setup without saving this config.
[2] Save this configuration to nvram and exit.
Enter your selection [2]: 2
选择2保存设置并存入NVRAM中
Building configuration...
[OK] Use the enabled mode 'configure' command to modify this configuration.
Press RETURN to get started!
路由器重新启动
00:00:08: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
00:00:08: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to down
00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
00:03:18: %IP-5-WEBINST_KILL: Terminating DNS process
00:03:24: %SYS-5-RESTART: System restarted --
RouterA>
进入用户模式
RouterA>en
Password:
RouterA#
进入全局模式
RouterA#sh run
查看现在运行的配置
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname RouterA
enable password bbb
memory-size iomem 25
ip subnet-zero
speed auto
full-duplex
interface Serial0/0
clockrate 2000000
speed auto
full-duplex
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
password ccc
login
end
现在您就完成了了一个新路由器的基本配置,接下来就可以进行进一步的详细配置了.
