CISCO路由器之广域网协议设置
路由器
17人已加入
CISCO路由器之广域网协议设置
一、HDLC
HDLC是CISCO路由器使用的缺省协议,一台新路由器在未指定封装协议时默认使用HDLC封装。
1.        有关命令
端口设置
任务
命令
设置HDLC封装
encapsulation hdlc
设置DCE端线路速度
clockrate speed
复位一个硬件接口
clear interface serial unit
显示接口状态
show interfaces serial [unit] 1
注:1.以下给出一个显示Cisco同步串口状态的例子.
Router#show interface serial 0
Serial 0 is up, line protocol is up
Hardware is MCI Serial
Internet address is 150.136.190.203, subnet mask is 255.255.255.0
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 0:00:07, output 0:00:00, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
Five minute input rate 0 bits/sec, 0 packets/sec
Five minute output rate 0 bits/sec, 0 packets/sec
16263 packets input, 1347238 bytes, 0 no buffer
Received 13983 broadcasts, 0 runts, 0 giants
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 2 abort
22146 packets output, 2383680 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets, 0 restarts
1 carrier transitions
2.        举例
路由器
设置如下:
Router1:
interface Serial0
 ip address 192.200.10.1 255.255.255.0
 clockrate 1000000
Router2:
interface Serial0
 ip address 192.200.10.2 255.255.255.0
3.      举例使用E1线路实现多个64K专线连接.
相关命令:
任务
命令
进入controller配置模式
controller {t1 | e1} number
选择帧类型
 framing {crc4 | no-crc4}
选择line-code类型
 linecode {ami | b8zs | hdb3}
建立逻辑通道组与时隙的映射
 channel-group number timeslots range1
显示controllers接口状态
show controllers e1 [slot/port]2
注: 1. 当链路为T1时,channel-group编号为0-23, Timeslot范围1-24; 当链路为E1时, channel-group编号为0-30, Timeslot范围1-31.
2.使用show controllers e1观察controller状态,以下为帧类型为crc4时controllers正常的状态.
Router# show controllers e1
e1 0/0 is up.
Applique type is Channelized E1 - unbalanced
Framing is CRC4, Line Code is HDB3  No alarms detected.
Data in current interval (725 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)     0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
以下例子为E1连接3条64K专线, 帧类型为NO-CRC4,非平衡链路,路由器具体设置如下:
shanxi#wri t
Building configuration...
Current configuration:
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname shanxi
enable secret 5 $1$XN08$Ttr8nfLoP9.2RgZhcBzkk/
enable password shanxi
ip subnet-zero
controller E1 0
framing NO-CRC4
channel-group 0 timeslots 1
channel-group 1 timeslots 2
channel-group 2 timeslots 3
interface Ethernet0
ip address 133.118.40.1 255.255.0.0
media-type 10BaseT
interface Ethernet1
no ip address
shutdown
interface Serial0:0
ip address 202.119.96.1 255.255.255.252
no ip mroute-cache
interface Serial0:1
ip address 202.119.96.5 255.255.255.252
no ip mroute-cache
interface Serial0:2
ip address 202.119.96.9 255.255.255.252
no ip mroute-cache
no ip classless
ip route 133.210.40.0 255.255.255.0 Serial0:0
ip route 133.210.41.0 255.255.255.0 Serial0:1
ip route 133.210.42.0 255.255.255.0 Serial0:2
line con 0
line aux 0
line vty 0 4
password shanxi
login
end
二、PPP
PPP(Point-to-Point Protocol)是SLIP(Serial Line IP protocol)的继承者,它提供了跨过同步和异步电路实现路由器到路由器(router-to-router)和主机到网络(host-to-network)的连接。
CHAP(Challenge Handshake Authentication Protocol)和PAP(Password Authentication Protocol) (PAP)通常被用于在PPP封装的串行线路上提供安全性认证。使用CHAP和PAP认证,每个路由器通过名字来识别,可以防止未经授权的访问。
CHAP和PAP在RFC 1334上有详细的说明。
1.        有关命令
端口设置
任务
命令
设置PPP封装
encapsulation ppp1
设置认证方法
ppp authentication {chap | chap pap | pap chap | pap} [if-needed] [list-name | default] [callin]
指定口令
username name password secret
设置DCE端线路速度
clockrate speed
注:1、要使用CHAP/PAP必须使用PPP封装。在与非Cisco路由器连接时,一般采用PPP封装,其它厂家路由器一般不支持Cisco的HDLC封装协议。
2.        举例
路由器Router1和Router2的S0口均封装PPP协议,采用CHAP做认证,在Router1中应建立一个用户,以对端路由器主机名作为用户名,即用户名应为router2。同时在Router2中应建立一个用户,以对端路由器主机名作为用户名,即用户名应为router1。所建的这两用户的password必须相同。
 路由器
设置如下:
Router1:
hostname router1
username router2 password xxx
interface Serial0
clockrate 1000000
ppp authentication chap
Router2:
hostname router2
username router1 password xxx
interface Serial0
三、x.25
1.        X25技术
X.25规范对应OSI三层,X.25的第三层描述了分组的格式及分组交换的过程。X.25的第二层由LAPB(Link Access Procedure, Balanced)实现,它定义了用于DTE/DCE连接的帧格式。X.25的第一层定义了电气和物理端口特性。
X.25网络设备分为数据终端设备(DTE)、数据电路终端设备(DCE)及分组交换设备(PSE)。DTE是X.25的末端系统,如终端、计算机或网络主机,一般位于用户端,Cisco路由器就是DTE设备。DCE设备是专用通信设备,如调制解调器和分组交换机。PSE是公共网络的主干交换机。
X.25定义了数据通讯的电话网络,每个分配给用户的x.25 端口都具有一个x.121地址,当用户申请到的是SVC(交换虚电路)时,x.25一端的用户在访问另一端的用户时,首先将呼叫对方x.121地址,然后接收到呼叫的一端可以接受或拒绝,如果接受请求,于是连接建立实现数据传输,当没有数据传输时挂断连接,整个呼叫过程就类似我们拨打普通电话一样,其不同的是x.25可以实现一点对多点的连接。其中x.121地址、htc均必须与x.25服务提供商分配的参数相同。X.25 PVC(永久虚电路),没有呼叫的过程,类似DDN专线。
2.        有关命令:
任务
命令
设置X.25封装
encapsulation x25 [dce]
设置X.121地址
x25 address x.121-address
设置远方站点的地址映射
x25 map protocol address [protocol2 address2[...[protocol9 address9]]] x121-address [option]
设置最大的双向虚电路数
x25 htc citcuit-number1
设置一次连接可同时建立的虚电路数
x25 nvc count2
设置x25在清除空闲虚电路前的等待周期
x25 idle minutes
重新启动x25,或清一个svc,启动一个pvc相关参数
clear x25 {serial number | cmns-interface mac-address} [vc-number] 3
清x25虚电路
clear x25-vc
显示接口及x25相关信息
show x25 interface
show x25 map
show x25 vc
注:1、虚电路号从1到4095,Cisco路由器默认为1024,国内一般分配为16。
   2、虚电路计数从1到8,缺省为1。
   3、在改变了x.25各层的相关参数后,应重新启动x25(使用clear x25 {serial number | cmns-interface mac-address} [vc-number]或clear x25-vc命令),否则新设置的参数可能不能生效。同时应对照服务提供商对于x.25交换机端口的设置来配置路由器的相关参数,若出现参数不匹配则可能会导致连接失败或其它意外情况。
3.        实例:
3.1. 在以下实例中每二个路由器间均通过svc实现连接。
路由器
路由器设置如下:
Router1:
interface Serial0
    encapsulation x25
    x25 address 110101
    x25 htc 16
    x25 nvc 2
    x25 map ip 192.200.10.2 110102 broadcast
    x25 map ip 192.200.10.3 110103 broadcast
Router2:
interface Serial0
    encapsulation x25
    x25 address 110102
    x25 htc 16
    x25 nvc 2
    x25 map ip 192.200.10.1 110101 broadcast
Router:
interface Serial0
    encapsulation x25
    ip address 192.200.10.3 255.255.255.0
    x25 address 110103
    x25 htc 16
    x25 nvc 2
相关调试命令:
clear x25-vc
show x25 map
show x25 route
show x25 vc
3.2. 在以下实例中路由器router1和router2均通过svc与router连接,但router1和router2不通过svc直接连接,此三个路由器的串口运行RIP路由协议,使用了子接口的概念。由于使用子接口,router1和router2均学习到了访问对方局域网的路径,若不使用子接口,router1和router2将学不到到对方局域网的路由。
子接口(Subinterface)是一个物理接口上的多个虚接口,可以用于在同一个物理接口上连接多个网。我们知道为了避免路由循环,路由器支持split horizon法则,它只允许路由更新被分配到路由器的其它接口,而不会再分配路由更新回到此路由被接收的接口。
无论如何,在广域网环境使用基于连接的接口(象 X.25和Frame Relay),同一接口通过虚电路(vc)连接多台远端路由器时,从同一接口来的路由更新信息不可以再被发回到相同的接口,除非强制使用分开的物理接口连接不同的路由器。Cisco提供子接口(subinterface)作为分开的接口对待。你可以将路由器逻辑地连接到相同物理接口的不同子接口, 这样来自不同子接口的路由更新就可以被分配到其他子接口,同时又满足split horizon法则。
路由器
Router1:
interface Serial0
encapsulation x25
x25 address 110101
x25 htc 16
x25 nvc 2
router rip
network 192.200.10.0
Router2:
interface Serial0
encapsulation x25
ip address 192.200.11.2 255.255.255.0
x25 address 110102
x25 htc 16
 x25 nvc 2
x25 map ip 192.200.11.3 110103 broadcast
router rip
network 192.200.11.0
Router:
interface Serial0
encapsulation x25
x25 address 110103
x25 htc 16
x25 nvc 2
interface Serial0.1 point-to-point
interface Serial0.2 point-to-point
ip address 192.200.11.3 255.255.255.0
x25 map ip 192.200.11.2 110102 broadcast
router rip
四、Frame Relay
1.      帧中继技术
路由器
帧中继是一种高性能的WAN协议,它运行在OSI参考模型的物理层和数据链路层。它是一种数据包交换技术,是X.25的简化版本。它省略了X.25的一些强健功能,如提供窗口技术和数据重发技术,而是依靠高层协议提供纠错功能,这是因为帧中继工作在更好的WAN设备上,这些设备较之X.25的WAN设备具有更可靠的连接服务和更高的可靠性,它严格地对应于OSI参考模型的最低二层,而X.25还提供第三层的服务,所以,帧中继比X.25具有更高的性能和更有效的传输效率。
帧中继广域网的设备分为数据终端设备(DTE)和数据电路终端设备(DCE),Cisco路由器作为 DTE设备。
帧中继技术提供面向连接的数据链路层的通信,在每对设备之间都存在一条定义好的通信链路,且该链路有一个链路识别码。这种服务通过帧中继虚电路实现,每个帧中继虚电路都以数据链路识别码(DLCI)标识自己。DLCI的值一般由帧中继服务提供商指定。帧中继即支持PVC也支持SVC。
帧中继本地管理接口(LMI)是对基本的帧中继标准的扩展。它是路由器和帧中继交换机之间信令标准,提供帧中继管理机制。它提供了许多管理复杂互联网络的特性,其中包括全局寻址、虚电路状态消息和多目发送等功能。
2.        有关命令:
端口设置
任务
命令
设置Frame Relay封装
encapsulation frame-relay[ietf] 1
设置Frame Relay LMI类型
frame-relay lmi-type {ansi | cisco | q933a}2
设置子接口
interface interface-type interface-number.subinterface-number [multipoint|point-to-point]
映射协议地址与DLCI
frame-relay map protocol protocol-address dlci [broadcast]3
设置FR DLCI编号
frame-relay interface-dlci dlci [broadcast]
注:1.若使Cisco路由器与其它厂家路由设备相连,则使用Internet工程任务组(IETF)规定的帧中继封装格式。
2.从Cisco IOS版本11.2开始,软件支持本地管理接口(LMI)“自动感觉”, “自动感觉”使接口能确定交换机支持的LMI类型,用户可以不明确配置LMI接口类型。
3.broadcast选项允许在帧中继网络上传输路由广播信息。
3.        帧中继point to point配置实例:
路由器
Router1:
interface serial 0
interface serial 0.1 point-to-point
ip address 172.16.1.1 255.255.255.0
frame-reply interface-dlci 105
interface serial 0.2 point-to-point
ip address 172.16.2.1 255.255.255.0
frame-reply interface-dlci 102
interface serial 0.3 point-to-point
ip address 172.16.4.1 255.255.255.0
frame-reply interface-dlci 104
Router2:
interface serial 0
ip address 172.16.2.2 255.255.255.0
frame-reply interface-dlci 201
ip address 172.16.3.1 255.255.255.0
frame-reply interface-dlci 203
相关调试命令:
show frame-relay lmi
show frame-relay map
show frame-relay pvc
show frame-relay route
go top
4.        帧中继 Multipoint 配置实例:
路由器
Router1:
interface serial 0
encapsulation frame-reply
interface serial 0.1 multipoint
ip address 172.16.1.2 255.255.255.0
frame-reply map ip 172.16.1.1 201 broadcast
frame-reply map ip 172.16.1.3 301 broadcast
frame-reply map ip 172.16.1.4 401 broadcast
Router2:
interface serial 0
frame-reply map ip 172.16.1.2 102 broadcast
frame-reply map ip 172.16.1.3 102 broadcast
frame-reply map ip 172.16.1.4 102 broadcast
五、ISDN
1.        综合数字业务网(ISDN)
综合数字业务网(ISDN)由数字电话和数据传输服务两部分组成,一般由电话局提供这种服务。ISDN的基本速率接口(BRI)服务提供2个B信道和1个D信道(2B+D)。BRI的B信道速率为64Kbps,用于传输用户数据。D信道的速率为16Kbps,主要传输控制信号。在北美和日本,ISDN的主速率接口(PRI)提供23个B信道和1个D信道,总速率可达1.544Mbps,其中D信道速率为64Kbps。而在欧洲、澳大利亚等国家,ISDN的PRI提供30个B信道和1个64Kbps D信道,总速率可达2.048Mbps。我国电话局所提供ISDN PRI为30B+D。
2.        基本命令
任务
命令
设置ISDN交换类型
isdn switch-type switch-type1
接口设置
interface bri 0
设置PPP封装
encapsulation ppp
设置协议地址与电话号码的映射
dialer map protocol next-hop-address [name hostname] [broadcast] [dial-string]
启动PPP多连接
ppp multilink
设置启动另一个B通道的阈值
dialer load-threshold load
显示ISDN有关信息
show isdn {active | history | memory | services | status [dsl | interface-type number] | timers}
注:1.交换机类型如下表,国内交换机一般为basic-net3。
按区域分关键字
交换机类型
Australia
basic-ts013
Australian TS013 switches
Europe
basic-1tr6
German 1TR6 ISDN switches
basic-nwnet3
Norway NET3 switches (phase 1)
basic-net3
NET3 ISDN switches (UK, Denmark, and other nations); covers the Euro-ISDN E-DSS1 signalling system
primary-net5
NET5 switches (UK and Europe)
vn2
French VN2 ISDN switches
vn3
French VN3 ISDN switches
Japan
ntt
Japanese NTT ISDN switches
primary-ntt
Japanese ISDN PRI switches
North America
basic-5ess
AT&T basic rate switches
basic-dms100
NT DMS-100 basic rate switches
basic-ni1
National ISDN-1 switches
primary-4ess
AT&T 4ESS switch type for the U.S. (ISDN PRI only)
primary-5ess
AT&T 5ESS switch type for the U.S. (ISDN PRI only)
primary-dms100
NT DMS-100 switch type for the U.S. (ISDN PRI only)
New Zealand
basic-nznet3
New Zealand Net3 switches
3.        ISDN实现DDR(dial-on-demand routing)实例:
路由器
设置如下:
Router1:
hostname router1
user router2 password cisco
isdn switch-type basic-net3
interface bri 0
encapsulation ppp
dialer map ip 192.200.10.2 name router2 572
dialer load-threshold 80
ppp multilink
dialer-group 1
dialer-list 1 protocol ip permit
Router2:
hostname router2
user router1 password cisco
interface bri 0
encapsulation ppp
dialer map ip 192.200.10.1 name router1 571
ppp multilink
dialer-group 1
Cisco路由器同时支持回拨功能,我们将路由器Router1作为Callback Server,Router2作为Callback Client。
与回拨相关命令:
任务
命令
映射协议地址和电话号码,并在接口上使用在全局模式下定义的PPP回拨的映射类别。
dialer map protocol address name hostname class classname dial-string
设置接口支持PPP回拨
ppp callback accept
在全局模式下为PPP回拨设置映射类别
map-class dialer classname
通过查找注册在dialer map里的主机名来决定回拨.
 dialer callback-server [username]
设置接口要求PPP回拨
ppp callback request
设置如下:
Router1:
hostname router1
interface bri 0
encapsulation ppp
dialer map ip 192.200.10.2 name router2 class s3 572
ppp callback accept
ppp multilink
dialer-group 1
map-class dialer s3
dialer callback-server username
Router2:
hostname router2
interface bri 0
encapsulation ppp
ppp multilink
dialer-group 1
相关调试命令:
debug dialer
debug isdn event
debug isdn q921
debug isdn q931
debug ppp authentication
debug ppp error
debug ppp negotiation
debug ppp packet
show dialer
show isdn status
举例:执行debug dialer命令观察router2呼叫router1,router1回拨router2的过程.
router1#debug dialer
router2#ping 192.200.10.1
router1#
00:03:50: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
00:03:50: BRI0:1:PPP callback Callback server starting to router2 572
00:03:50: BRI0:1: disconnecting call
00:03:50: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
00:03:51: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
00:03:52: callback to router2 already started
00:03:52: BRI0:2: disconnecting call
00:03:52: %LINK-3-UPDOWN: Interface BRI0:2, changed state to down
00:04:05: : Callback timer expired
00:04:05: BRI0:beginning callback to router2 572
00:04:05: BRI0: Attempting to dial 572
00:04:05: Freeing callback to router2 572
00:04:05: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
00:04:05: BRI0:1: No callback negotiated
00:04:05: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
00:04:05: dialer Protocol up for Vi1
00:04:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state
to up
00:04:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, chang
ed state to up
00:04:11: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 572
#router1
4.      ISDN访问首都在线263网实例:
路由器
本地局部网地址为10.0.0.0/24,属于保留地址,通过NAT地址翻译功能,局域网用户可以通过ISDN上263网访问Internet。263的ISDN电话号码为2633,用户为263,口令为263,所涉及的命令如下表:
任务
命令
指定接口通过PPP/IPCP地址协商获得IP地址
ip address negotiated
指定内部和外部端口
ip nat {inside | outside}
使用ppp/pap作认证
ppp authentication pap callin
指定接口属于拨号组1
dialer-group 1
定义拨号组1允许所有IP协议
设定拨号,号码为2633
dialer string 2633
设定登录263的用户名和口令
ppp pap sent-username 263 password 263
设定默认路由
ip route 0.0.0.0 0.0.0.0 bri 0
设定符合访问列表2的所有源地址被翻译为bri 0所拥有的地址
ip nat inside source list 2 interface bri 0 overload
设定访问列表2,允许所有协议
access-list 2 permit any
具体配置如下:
hostname Cisco2503
ip subnet-zero
no ip domain-lookup
ip routing
interface Ethernet 0
ip address 10.0.0.1 255.255.255.0
ip nat inside
no shutdown
interface Serial 0
shutdown
no description
no ip address
interface Serial 1
shutdown
no description
no ip address
interface bri 0
ip nat outside
encapsulation ppp
ppp multilink
dialer-group 1
dialer hold-queue 10
dialer string 2633
dialer idle-timeout 120
no cdp enable
no ip split-horizon
no shutdown
ip classless
! Static Routes
! Access Control List 2
! Dynamic NAT
snmp-server community public ro
line console 0
exec-timeout 0 0
line vty 0 4
end
5.        Cisco765M通过ISDN拨号上263
由于Cisco765的设置命令与我们常用的Cisco路由器的命令不同,所以以下列举了通过Cisco765上263访问Internet的具体命令行设置步骤。
>set system c765
c765> set multidestination on
c765> set switch net3
c765> set ppp multilink on
c765> cd lan
c765:LAN> set ip routing on
c765:LAN> set ip address 10.0.0.1
c765:LAN> set ip netmask 255.0.0.0
c765:LAN> set briding off
c765:LAN>cd
c765> set user remotenet
New user remotenet being created
c765:remotenet> set ip routing on
c765:remotenet> set bridging off
c765:remotenet> set ip framing none
c765:remotenet> set ppp clientname 263
c765:remotenet> set ppp password client
Enter new Password: 263
Re-Type new Password: 263
c765:remotenet> set ppp authentication out none
c765:remotenet> set ip address 0.0.0.0
c765:remotenet> set ip netmask 0.0.0.0
c765:remotenet> set ppp address negotiation local on
c765:remotenet> set ip pat on
c765:remotenet> set ip route destination 0.0.0.0/0 gateway 0.0.0.0
c765:remotenet> set number 2633
c765:remotenet> set active
命令描述如下:
任务
命令
设置路由器系统名称
set system c765
允许路由器呼叫多个目的地
设置ISDN交换机类型为NET3
set switch net3
允许点到点间多条通道连接实现负载均衡
关掉桥接
set briding off
建立用户预制文件用于设置拨号连接参数- 可以设置多个用户预制文件用于相同的物理端口对应于不同的连接。
set user remotenet
使用PPP/IPCP
set ip framing none
设置上网用户帐号
设置上网口令
不用PPP/CHAP或PAP做认证
允许地址磋商
设置地址翻译
set ip pat on
设置默认路由
设置ISP的电话号码
set number 2633
激活用户预制文件
set active
六、PSTN
  电话网络(PSTN)是目前普及程度最高、成本最低的公用通讯网络,它在网络互连中也有广泛的应用。电话网络的应用一般可分为两种类型,一种是同等级别机构之间以按需拨号(DDR)的方式实现互连,一种是ISP为拨号上网为用户提供的远程访问服务的功能。
1.     远程访问
路由器
1.1.Access Server基本设置:
选用Cisco2511作为访问服务器,采用IP地址池动态分配地址.远程工作站使用WIN95拨号网络实现连接。
全局设置:
任务
命令
设置用户名和密码
username username password password
设置用户的IP地址池
ip local pool {default | pool-name low-ip-address [high-ip-address]}
指定地址池的工作方式
ip address-pool [dhcp-proxy-client | local]
基本接口设置命令:
任务
命令
设置封装形式为PPP
encapsulation ppp
启动异步口的路由功能
async default routing
设置异步口的PPP工作方式
async mode {dedicated | interactive}
设置用户的IP地址
peer default ip address {ip-address | dhcp | pool [pool-name]}
设置IP地址与Ethernet0相同
ip unnumbered ethernet0
line拨号线设置:
任务
命令
设置modem的工作方式
modem {inout|dialin}
自动配置modem类型
modem autoconfig discovery
设置拨号线的通讯速率
speed speed
设置通讯线路的流控方式
flowcontrol {none | software [lock] [in | out] | hardware [in | out]}
连通后自动执行命令
autocommand command
访问服务器设置如下:
Router:
hostname Router
enable secret 5 $1$EFqU$tYLJLrynNUKzE4bx6fmH//
interface Ethernet0
ip address 10.111.4.20 255.255.255.0
interface Async1
ip unnumbered Ethernet0
encapsulation ppp
keepalive 10
async mode interactive
peer default ip address pool Cisco2511-Group-142
ip local pool Cisco2511-Group-142 10.111.4.21 10.111.4.36
line con 0
exec-timeout 0 0
password cisco
line 1 16
modem InOut
modem autoconfigure discovery
flowcontrol hardware
line aux 0
transport input all
line vty 0 4
password cisco
end
相关调试命令:
show interface
show line
1.2.       Access Server通过Tacacs服务器实现安全认证:
使用一台WINDOWS NT服务器作为Tacacs服务器,地址为10.111.4.2,运行Cisco2511随机带的Easy ACS 1.0软件实现用户认证功能.
相关设置:
任务
命令
激活AAA访问控制
aaa new-model
用户登录时默认起用Tacacs+做AAA认证
aaa authentication login default tacacs+
列表名为no_tacacs使用ENABLE口令做认证
aaa authentication login no_tacacs enable
在运行PPP的串行线上采用Tacacs+做认证
aaa authentication ppp default tacacs+
由TACACS+服务器授权运行EXEC
aaa authorization exec tacacs+
由TACACS+服务器授权与网络相关的服务请求。
aaa authorization network tacacs+
为EXEC会话运行记帐.进程开始和结束时发通告给TACACS+服务器。
aaa accounting exec start-stop tacacs+
为与网络相关的服务需求运行记帐包括SLIP,PPP,PPP NCPs,ARAP等.在进程开始和结束时发通告给TACACS+服务器。
aaa accounting network start-stop tacacs+
指定Tacacs服务器地址
tacacs-server host 10.111.4.2
在Tacacs+服务器和访问服务器设定共享的关键字,访问服务器和Tacacs+服务器使用这个关键字去加密口令和响应信息。这里使用tac作为关键字。
tacacs-server key tac
访问服务器设置如下:
hostname router
aaa new-model
enable secret 5 $1$kN4g$CvS4d2.rJzWntCnn/0hvE0
interface Ethernet0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Group-Async1
encapsulation ppp
no cdp enable
group-range 1 16
line con 0
exec-timeout 0 0
password cisco
login authentication no_tacacs
line 1 16
login authentication tacacs
modem InOut
modem autoconfigure type usr_courier
autocommand ppp
transport input all
stopbits 1
rxspeed 115200
txspeed 115200
line aux 0
transport input all
line vty 0 4
password cisco
end
2.      DDR(dial-on-demand routing)实例
路由器
此例通过Cisco 2500系列路由器的aux端口实现异步拨号DDR连接。Router1拨号连接到Router2。其中采用PPP/CHAP做安全认证,在Router1中应建立一个用户,以对端路由器主机名作为用户名,即用户名应为Router2。同时在Router2中应建立一个用户,以对端路由器主机名作为用户名,即用户名应为Router1。所建的这两用户的password必须相同。
相关命令如下:
任务
命令
设置路由器与modem的接口指令
chat-script script-name EXPECT SEND EXPECT SEND (etc.)
设置端口在挂断前的等待时间
dialer idle-timeout seconds
设置协议地址与电话号码的映射
dialer map protocol next-hop-address [name hostname] [broadcast] [modem-script
modem-regexp] [system-script system-regexp] [dial-string]
设置电话号码
dialer string dial-string
指定在特定线路下路由器默认 使用的chat-script
script {dialer|reset} script-name
Router1:
hostname Router1
enable secret 5 $1$QKI7$wXjpFqC74vDAyKBUMallw/
username Router2 password cisco
chat-script cisco-default  "" "AT" TIMEOUT 30 OK "ATDT \T" TIMEOUT 30 CONNECT \c
interface Ethernet0
interface Async1
encapsulation ppp
async mode dedicated
dialer in-band
dialer idle-timeout 60
dialer map ip 192.200.10.2 name Router2 modem-script cisco-default 573
dialer-group 1
ip route 10.0.1.0 255.255.255.0 192.200.10.2
line con 0
line aux 0
modem InOut
Router2:
hostname Router2
enable secret 5 $1$F6EV$5U8puzNt2/o9g.t56PXHo.
username Router1 password cisco
interface Ethernet0
ip address 10.0.1.1 255.255.255.0
interface Async1
encapsulation ppp
dialer in-band
dialer map ip 192.200.10.1 name Router1
dialer-group 1
ip route 10.0.0.0 255.255.255.0 192.200.10.1
line con 0
line aux 0
modem InOut
相关调试命令:
debug dialer
debug ppp error
debug ppp packet
show dialer
3.        异步拨号备份DDN专线:
路由器
   此例主连接采用DDN专线,备份线路为电话拨号。当DDN专线连接正常时,主端口S0状态为up,line protocol亦为up,则备份线路状态为standby,line protocol为down,此时所有通信均通过主接口进行。当主接口连接发生故障时,端口状态为down,则激活备份接口,完成数据通信。此方法不适合为X.25做备份。因为,配置封装为X.25的接口只要和X.25交换机之间的连接正常其接口及line protocol的状态亦为 up,它并不考虑其它地方需与之通信的路由器的状态如何,所以若本地路由器状态正常,而对方路由器连接即使发生故障,本地也不会激活备份线路。例4将会描述如何为X.25做拨号备份。
以下是相关命令:
任务
命令
指定主线路改变后,次线路状态发生改变的延迟时间
backup delay {enable-delay | never} {disable-delay | never}
指定一个接口作为备份接口
backup interface type number
hostname c2522rb
enable secret 5 $1$J5vn$ceYDe2FwPhrZi6qsIIz6g0
enable password cisco
username c4700 password 0 cisco
ip subnet-zero
chat-script reset atz
interface Ethernet0
ip address 16.122.51.254 255.255.255.0
no ip mroute-cache
interface Serial0
backup delay 10 10
backup interface Serial2
ip address 16.250.123.18 255.255.255.252
no ip mroute-cache
no fair-queue
interface Serial1
no ip address
no ip mroute-cache
shutdown
interface Serial2
physical-layer async
ip address 16.249.123.18 255.255.255.252
encapsulation ppp
dialer in-band
dialer map ip 16.249.123.17 name c4700 6825179
dialer-group 1
interface Serial3
no ip address
shutdown
no cdp enable
interface Serial4
no ip address
shutdown
no cdp enable
interface Serial5
no ip address
no ip mroute-cache
shutdown
interface Serial6
no ip address
no ip mroute-cache
shutdown
interface Serial7
no ip address
no ip mroute-cache
shutdown
interface Serial8
no ip address
no ip mroute-cache
shutdown
interface Serial9
no ip address
no ip mroute-cache
shutdown
interface BRI0
no ip address
no ip mroute-cache
shutdown
router eigrp 200
network 16.0.0.0
ip classless
line con 0
line 2
script dialer cisco-default
script reset reset
modem InOut
rxspeed 38400
txspeed 38400
line aux 0
line vty 0 4
password cisco
login
end
c2522rb#
4.       异步拨号备份X.25:
   设置X.25的拨号备份,首先X.25连接的端口必须运行动态路由协议,异步拨号口必须使用静态路由.本例选择EIGRP作为路由选择协议,将静态路由的Metric的值设置为200,由于EIGRP的默认Metric为90,所以当同时有两条路径通往同一网段时,其中Metric值小的路径生效,而当X.25连接出现问题时,路由器无法通过路由协议学习到路由表,则此时静态路由生效,访问通过拨号端口实现。当X.25连接恢复正常时,路由器又可以学习到路由表,则由于 Metric值的不同,静态路由自动被动态路由所代替,这样就实现了备份的功能。
路由器Router1配置如下:
hostname router1
enable secret 5 $1$UTvD$99YiY2XsRMxHudcYeHn.Y.
username router2 password cisco
ip subnet-zero
interface Ethernet0
ip address 202.96.38.100 255.255.255.0
interface Serial0
ip address 202.96.0.1 255.255.255.0
encapsulation x25
x25 address 10112227
x25 htc 16
x25 map ip 202.96.0.2 10112225 broadcast
interface Serial1
no ip address
shutdown
interface Async 1
ip address 202.96.1.1 255.255.255.252
encapsulation ppp
dialer in-band
dialer map ip 202.96.1.2 name router2 modem-script cisco-default 2113470
dialer-group 1
router eigrp 200
redistribute connected
network 202.96.0.0
ip route 202.96.37.0 255.255.255.0 202.96.1.2 200
line con 0
line aux 0
script reset reset
modem InOut
transport input all
rxspeed 38400
txspeed 38400
line vty 0 4
password cisco
login
end
路由器Router2配置如下:
hostname router2
enable secret 5 $1$T4IU$2cIqak8f/E4Ug6dLT0k.J0
username router1 password cisco
ip subnet-zero
interface Ethernet0
ip address 202.96.37.100 255.255.255.0
interface Serial0
ip address 202.96.0.2 255.255.255.0
no ip mroute-cache
encapsulation x25
x25 address 10112225
x25 htc 16
x25 map ip 202.96.0.1 10112227 broadcast
interface Serial1
no ip address
shutdown
interface Async1
ip address 202.96.1.2 255.255.255.252
encapsulation ppp
keepalive 30
dialer in-band
dialer wait-for-carrier-time 120
dialer map ip 202.96.1.1 name router1 modem-script cisco-default 2113469
dialer-group 1
router eigrp 200
redistribute static
network 202.96.0.0
no ip classless
ip route 202.96.38.0 255.255.255.0 202.96.1.1 200
line con 0
exec-timeout 0 0
line aux 0
script reset reset
modem InOut
transport input all
rxspeed 38400
txspeed 38400
line vty 0 4
password cisco
login
end
