DC1368A DC1368A评估板
KANA 发表于 2021-09-06 22:00:04
数据:
dc1368a DC1368A LT3080EDD-1 Demo Board | LT3080-1(x4), Paralleled, Single Resistor Prog Low Noise LDOs, 1.7V ≤ VIN ≤ 25V, VOUT = 1.2V @ 4.4A Demonstration circuit 1368A exercises four adjustable linear regulators in parallel using the LT3080-1, which incorporates an internal ballast resistor. The ballast resistor allows direct paralleling of devices without the need for PC board resistors or sensor resistors.The paralleled devices provide up to 4.4A of output current at 1.2V. Architected as a precision current source and voltage follower, the LT3080-1 can be used in many applications requiring high current, adjustability to zero output, and no heat sink. The device brings out the collector of the pass transistor to allow low dropout operation when used with multiple supplies. The LT3080-1's output voltage can be programmed to any level between 0V and 36V; however the demo board has a reduced input voltage range from 1.7V to 25V due to the input capacitor voltage rating. DC1368A
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
