DC1041A-A DC1041A-A评估板
KANA 发表于 2021-09-06 21:00:04
数据:
dc1041a-a DC1041A-A LTM4601 Demo Board | 4.5V ≤ VIN ≤ 20V, VOUT = 0.6V to 5V @ 12A Demonstration circuit DC1041A-A features the LTM4601EV, a 12A high efficiency, high density switch mode step-down converter. The input voltage range is from 4.5V to 20V. The output voltage is jumper selectable for popular voltages from 0.6V to 5V. The PLLIN pin supports synchronizing the μModule® regulator to an external clock. The TRACK/SS pin allows the user to program output ramp-up and ramp-down rates which may coincidentally or ratiometrically track with another supply’s output if desired. Output voltage margining of ±5% from the nominal value is available via the margin control pins MARG0 and MARG1. DC1041A-A
技术文档
数据手册(0)
