DC1083A-A DC1083A-A评估板
KANA 发表于 2021-09-06 21:00:04
数据:
dc1083a-a DC1083A-A LTM4603 Demo Board | Step-Down μModule Regulator, 4.5V ≤ VIN ≤ 20V, VOUT = 0.6V/1.2V/1.5V/1.8V/2.5V/3.3V/5V @ 6A Demonstration circuit DC1083A-A features the LTM4603, the high efficiency, high density step-down μModule® regulator. The input voltage range is from 4.5V to 20V. The output voltage is jumper programmable from 0.6V to 5V. The rated load current is 6A, but derating is necessary for certain VIN, VOUT, and thermal conditions. The LTM4603 can be synchronized to an external clock signal by applying the clock to the PLLIN pin. DC1083A-A
技术文档
数据手册(0)
