DC1083A-B DC1083A-B评估板
KANA 发表于 2021-09-06 21:00:04
数据:
dc1083a-b DC1083A-B LTM4603HVEV Demo Board Demonstration circuit DC1083A-B features the LTM4603HV, the high efficiency, high density step-down μModule® regulator. The input voltage range is from 4.5V to 28V. The output voltage is jumper programmable from 0.6V to 5V. The rated load current is 6A, while derating is necessary for certain VIN, VOUT, and thermal conditions. Applying an external clock signal to the PLLIN pin forces the μModule regulator to operate at the same frequency. DC1083A-B
技术文档
数据手册(0)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
