基于面向对象数据模型的信息管理系统
消耗积分:3 | 格式:rar | 大小:223 | 2009-02-21
王毅山
分享资料个
探讨了面向对象数据模型信息管理系统的结构设计和信息管理系统实现技术。系统设计采用面向对象数据模型,数据库结构采用对象-关系数据库。结合一个典型的教务信息管理系统实例说明,这一技术易于实现基于C/S和B/S结构的系统功能,并且易于维护、修改和功能扩充。
关 键 词 教务管理; 面向对象系统分析; 对象-关系数据库; 客观服务器
Abstract The development of Intranet structure and OOP technology has brought new concept of information administration system such as campus academic administration system, as well as the correspondent new developing technology. Based on a case study of a campus academic administration system, this paper explored the design of new system struture, and the technology approch of its developing, also summarized some key technic issues. The Object Orient Data Model and the Object-Relative Data Base System(ORDBS) was adapted in our system struture design and developing. The design process and result shows that this approch has explicit advantages to realize the system functions based on C/S and B/S struture, as well as to maitain or extend system functions.
Key words academic administration system; object-oriented systems analysis; object- relation database; client/server
评论(0)
发评论
下载排行榜
