当然有的人喜欢写get set,或者用BeanUtils 进行复制,代码只是工具,本文只是提供一种思路。
pom 配置:
<properties>
<project.build.sourceEncoding>UTF-8project.build.sourceEncoding>
<maven.compiler.source>1.8maven.compiler.source>
<maven.compiler.target>1.8maven.compiler.target>
<org.mapstruct.version>1.4.1.Finalorg.mapstruct.version>
<org.projectlombok.version>1.18.12org.projectlombok.version>
properties>
<dependencies>
<dependency>
<groupId>org.mapstructgroupId>
<artifactId>mapstructartifactId>
<version>${org.mapstruct.version}version>
dependency>
<dependency>
<groupId>org.projectlombokgroupId>
<artifactId>lombokartifactId>
<version>${org.projectlombok.version}version>
<scope>providedscope>
dependency>
<dependency>
<artifactId>mapstruct-processorartifactId>
dependency>
dependencies>
<build>
<plugins>
<plugin>
<groupId>org.apache.maven.pluginsgroupId>
<artifactId>maven-compiler-pluginartifactId>
<version>3.8.1version>
<configuration>
<source>1.8source>
<target>1.8target>
<annotationProcessorPaths>
<path>
path>
<path>
path>
configuration>
plugin>
plugins>
build>
关于lombok和mapstruct的版本兼容问题多说几句,maven插件要使用3.6.0版本以上、lombok使用1.16.16版本以上,另外编译的lombok mapstruct的插件不要忘了加上。否则会出现下面的错误:No property named "aaa" exists in source parameter(s). Did you mean "null"?
这种异常就是lombok编译异常导致缺少get setter方法造成的。还有就是缺少构造函数也会抛异常。
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
public class Student {
private String name;
private int age;
private GenderEnum gender;
private Double height;
private Date birthday;
public enum GenderEnum {
Male("1", "男"),
Female("0", "女");
private String code;
public String getCode() {
return this.code;
public String getName() {
return this.name;
GenderEnum(String code, String name) {
this.code = code;
this.name = name;
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
public class StudentVO {
private int age;
private String gender;
private String birthday;
@Mapper
public interface StudentMapper {
StudentMapper INSTANCE = Mappers.getMapper(StudentMapper.class);
@Mapping(source = "gender.name", target = "gender")
@Mapping(source = "birthday", target = "birthday", dateFormat = "yyyy-MM-dd HHss")
StudentVO student2StudentVO(Student student);
实体类是开发过程少不了的,就算是用工具生成肯定也是要有的,需要手写的部分就是这个Mapper的接口,编译完成后会自动生成相应的实现类
然后就可以直接用mapper进行实体的转换了
public class Test {
public static void main(String[] args) {
Student student = Student.builder().name("小明").age(6).gender(GenderEnum.Male).height(121.1).birthday(new Date()).build();
System.out.println(student);
//这行代码便是实际要用的代码
StudentVO studentVO = StudentMapper.INSTANCE.student2StudentVO(student);
System.out.println(studentVO);
mapper可以进行字段映射,改变字段类型,指定格式化的方式,包括一些日期的默认处理。
可以手动指定格式化的方法:
@Mapper
@Mapping(source = "gender", target = "gender")
default String getGenderName(GenderEnum gender) {
return gender.getName();
上面只是最简单的实体映射处理,下面介绍一些高级用法
属性映射基于上面的mapping配置
@Mapper
List students2StudentVOs(List studentList) ;
List list = new ArrayList<>();
list.add(student);
List result = StudentMapper.INSTANCE.students2StudentVOs(list);
System.out.println(result);
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
private int age;
@Data
@AllArgsConstructor
@Builder
@NoArgsConstructor
public class Course {
private String courseName;
private int sortNo;
private long id;
@Data
@Builder
@AllArgsConstructor
@NoArgsConstructor
private int age;
private String course;
@Mapper
@Mapping(source = "student.gender.name", target = "gender")
@Mapping(source = "student.birthday", target = "birthday", dateFormat = "yyyy-MM-dd HHss")
@Mapping(source = "course.courseName", target = "course")
StudentVO studentAndCourse2StudentVO(Student student, Course course);
public class Test {
Course course = Course.builder().id(1L).courseName("语文").build();
StudentVO studentVO = StudentMapper.INSTANCE.studentAndCourse2StudentVO(student, course);
@Mapper
@Mapping(target = "name", source = "student.name", defaultValue = "张三")
转自:toutiao.com/i6891531055631696395
