public class MyObject{ private Long id; private String name; private int age; private int gender; public Long getId(){ return id; } public void setId(Long id){ this.id = id; } public String getName(){ return name; } public void setName(String name){ this.name = name; } public int getAge(){ return age; } public void setAge(int age){ this.age = age; } public int getGender(){ return gender; } public void setGender(int gender){ this.gender = gender; } @Override public boolean equals(Object o){ if(this == o){ return true; } if(o == null || getClass() != o.getClass()){ return false; } MyObject obj = (MyObject) o; return age = obj.age && gender = obj.gender && Objects.equals(id,obj.id) && Objects.queals(name,obj.name); } @Override public int hashCode(){ return Objects.hash(id,name,age,gender); } @Override public String toString(){ return "MyObject{"+ "id="+id+ "name="+name+ "age="+age+ "gender="+gander+ "}"; } }
每个JavaBean都会充斥着如上述getter,setter,equals,hashCode和toString的模板代码,这看起来像一个偏胖的人(不得不承认Java是一个有缺陷的编程语言)。当我们安装好Lombok插件后,IDE便可以识别其酷炫的注解,使用Lombok的@Getter和@Setter注解后,代码会像下面这样看起来很苗条:@Getter @Setter public class MyObject{ private Long id; private String name; private int age; private int gender; @Override public boolean equals(Object o){ if(this == o){ return true; } if(o == null || getClass() != o.getClass()){ return false; } MyObject obj = (MyObject) o; return age = obj.age && gender = obj.gender && Objects.equals(id,obj.id) && Objects.queals(name,obj.name); } @Override public int hashCode(){ return Objects.hash(id,name,age,gender); } @Override public String toString(){ return "MyObject{"+ "id="+id+ "name="+name+ "age="+age+ "gender="+gander+ "}"; } }
你以为Lombok就这点能耐?它还能让你代码的“身材”更苗条,更魔鬼。上面的代码仍然还有改进的空间,我们可以用@EqualsAndHashCod注解替换到equals和hashCode方法:@Getter @Setter @EqualsAndHashCode public class MyObject{ private Long id; private String name; private int age; private int gender; @Override public String toString(){ return "MyObject{"+ "id="+id+ "name="+name+ "age="+age+ "gender="+gander+ "}"; } }
现在的代码是否看起来爽多了?但这还不是最爽的时候。既然其他方法都替换掉了,那把toString方法也一起拿掉吧.如你所愿,可以使用@ToString注解去掉对于的方法:@Getter @Setter @EqualsAndHashCode @ToString public class MyObject{ private Long id; private String name; private int age; private int gender; }
经过Lombok的戏法之后,相比一开始的代码,看起来是不是很酷炫,很苗条,很性感?你以为到此为止了?远不止于此。你会发现类名上一大坨注解看起来好别扭,Lombok提供了一个组合注解@Data,可以替换掉类名头上那坨像翔一样的东西:@Data public class MyObject{ private Long id; private String name; private int age; private int gender; }
现在,Lombok是否让你的对象成为了你心目中完美的样子?魔鬼的“身材”,酷炫精炼。Lombok还有其他一些注解,如@Slf4j,@NoArgsConstructor,@AllArgsConstructor等等,介绍Lombok用法不是本文重点。
以上代码行数的变化过程,也许是无数程序员爱上Lombok的主要原因吧,这就像一个肥胖的人逐渐变成一个身材苗条的人。同时也让你看到了一个现象:你以为程序员很懒吗?其他有些时候他们比你想象中的还要懒。在爽的同时,也为代码种下了祸根@AllArgsConstructor注解,它将提供一个巨型构造器,让外界有机会在初始化对象时修改类中所有的属性。首先,这是极其不安全的,因为类中某系属性我们是不希望被修改的;另外,如果某个类中有几十个属性存在,就会有一个包含几十个参数的构造器被Lombok注入到类中,这是不理智的行为;其次,构造器参数的顺序完全由Lombok所控制,我们并不能操控,只有当你需要调试时才发现有一个奇怪的“小强”在等着你;最后,在运行代码之前,所有JavaBean中的方法你只能想象他们长什么样子,你并不能看见。全部0条评论
