[RTT-创新应用设计]AB32VG1-4.wav搜索
嵌入式软件/开发板
73人已加入
该主题前面的链接
1.开箱  https://bbs.elecfans.com/jishu_2172464_1_1.html
2.sd卡 播放 https://bbs.elecfans.com/jishu_2173612_1_1.html
3.音量记忆、播放暂停功能实现 https://bbs.elecfans.com/jishu_2183725_1_1.html
此贴主要实现sd 卡根目录wav 文件搜索 ,并实现相应的播放
  1. 首先要通过字符串来识别是否是wav文件
//通过后缀名识别文件类型
uint8_t tell_type(char *p)
    int i=0;
    char *attr;
    while(i<200)
        if(*p=='\0')
            break;
        i++;
        p++;
    if(i==200)
        return 1;
    i=0;
    while(i<5)
        if(*p=='.')
            p++;
            attr=p;
            break;
        i++;
        p--;
    if(i==5)
        return 2;
    if((strcmp(attr,"WAV")==0)||(strcmp(attr,"wav")==0))
        return 0;
    else
            return 4;
2.扫描所有根目录文件,并记录wav个数及相应的index
uint16_t wavGetNum(uint8_t*path)
    DIR tdir;
    uint16_t rval =0;
    uint8_t* fn;
   // DWORD tmp;
    DWORD fileindex=0;
    uint8_t res = f_opendir(&tdir, (const TCHAR*)path);
    tfileinfo.fsize = 255;
    if(res ==FR_OK){
        //LOG_I("open root dir sucess");
        while(1){
            fileindex++;
           // tmp = tdir.dptr;
           // LOG_I("dir_ofset %d",tmp);
            res = f_readdir(&tdir, &tfileinfo);
            if(res!=FR_OK||tfileinfo.fname[0]==0){
                //LOG_I("found the end");
                break;
            res =tell_type(tfileinfo.fname);
            if(res==0){
               // LOG_I("get the wav");
                wavIndex[rval] = fileindex-1;//get the index
                rval++;
        }//endwhile
    else{
        LOG_I("open root dir fail");
    return rval;
3.在sd 卡mount 处进行 wav文件扫描,并获取相应的wav名称
uint8_t* getFilePath(uint32_t index,uint8_t* path)
    DIR filedir;
    uint8_t *filepath =NULL;
    uint8_t res = f_opendir(&filedir, path);
    if(res == FR_OK){
       // LOG_I("dir_ofset %d",index);
        f_seekdir(&filedir, index);
       // LOG_I("dir_ofset %d",filedir.dptr);
        res =f_readdir(&filedir, &tfileinfo);
        if(res== FR_OK){
            //LOG_I("get the file %s",tfileinfo.fname);
            filepath = &wavFileName[0];
            strcpy(filepath,&tfileinfo.fname[0]);
        else {
            LOG_I("open file name error");
    else{
    return filepath;
实际运行log
RTThread
