MAX9249 Gigabit multimedia ser
新品快讯
30人已加入
MAX9249 Gigabit multimedia serial link with integrated full-duplex control channel reduces EMI and saves cost
LVDS SerDes chipset simplifies design, saves space and cost, and reduces EMI.
SUNNYVALE, CA—May 18, 2010—Maxim Integrated Products (NASDAQ: MXIM) introduces the latest member of its high-speed LVDS serializer family: the MAX9249 serializer with LVDS system interface. This serializer pairs with the MAX9260 deserializer to form a gigabit multimedia chipset that provides a complete bidirectional digital-video link over a single DC-balanced twisted-pair or differential line. Maxim's proprietary, differential, full-duplex control channel eliminates the need for an external CAN or LIN interface, thus simplifying design while saving space and cost. This approach enables bidirectional communication with the display module, as well as programming of camera settings through a UART/I²C interface on a frame-by-frame basis. The MAX9249/MAX9260 chipset is ideal for automotive infotainment and camera applications such as navigation, sign recognition, collision avoidance, night vision, and lane departure.
Additionally, the MAX9249/MAX9260 offer programmable spread-spectrum modulation to reduce EMI, making it easier to pass automotive compliance tests. This chipset allows isolation between the serializer and deserializer through AC-coupling, provides hot-swap capability to increase fault tolerance, and offers "on-the-fly" frequency programming. Line fault detection and integrated self-test features check for link integrity at system power-up.
The MAX9249 operates from a 1.8V core supply and features a separate input supply for interfacing to 1.8V to 3.3V logic levels. This serializer is packaged in a 7mm x 7mm, 48-pin TQFP and is fully specified over the -40°C to +105°C temperature range. Prices start at $5.25 (1000-up, FOB USA). Device data sheets, evaluation kits, and samples are available under NDA.
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6300 products serving the industrial, communications, consumer, and computing markets.
  • 相关推荐
  • 热点推荐
  • MAX9249
