制作12db圆筒天线的方法及公式
电子制作
259人已加入
圆筒天线的制作
We chose to build the antenna for 2.442GHz, or channel 7, as this is close to the center of the 13 channels available to us (US designs use channel 6 (2.437Ghz), as they have 11 channels). I have included a key lengths calculator in the form below. Nb.Rectangular waveguides use a different formulae (see Rectangular Waveguide).
Frequency频率
GHz
Diameter   直径 mm (Inside Measurement)
Free Space
Wavelength
mm
Waveguide
Wavelength
mm
最大频率 GHz
最小频率 GHz
截止频率 GHz
Probe Length mm 探针长度
Open End to Probe mm (Open End to probe center)
Probe to Reflector探针到圆筒后面反射体 mm (Probe center to Reflector)
Inside Length mm (Reflector to Opening)
The final product only needs to be accurate to about 1mm as this will only shift the frequency within the range of the 802.11 spectrum. A smaller cavity length will shift the frequency response to that slot to a higher channel. A longer slot cavity length will shift it down.
Methods and madness
I measured to .1mm using vernier callipers, on the assumption that errors in cutting might bring that closer to the 1mm error mark. There are only one to make, and you can't go too wrong, i.e. the probe (N-Socket) position.
Misc Notes
    * The probe is a 2mm diameter copper wire soldered into an N-Socket and cut to 31mm (1/4 free space wavelength, including the protruding bit of the N-Socket).
    * 探针采用的是2mm直径的铜线焊接在N接头的槽上。探针长度为31mm,包含N接头突起的部分。
    * The N-Socket is held down with nylon screws. If you use metal screws, use stainless steal ones and keep them short so they don't protrude into the cavity.
    * Water in the antenna, or spider and insects will be a problem. One suggestion is to seal around the edges of the reflector with silicone and cover the open end with a piece of plastic (microwave friendly and thin).
N-Socket with 1/4 wavelength copper wire (including the length of the bit of the N-Socket it is soldered into). This becomes the probe for the antenna.
