18b20测温c51源程序
控制/MCU
1933人已加入
#include
#include
#define   BUSY1    (DQ1==0)
sbit      DQ1    =  P0^4;
unsigned char idata TMP;
unsigned char idata TMP_d;
unsigned char f;
void wr_ds18_1(char dat);
unsigned char rd_ds18_1();
/***************延时程序,单位us,大于10us*************/
void time_delay(unsigned char time)
  time=time-10;
  time=time/6;
  while(time!=0)time--;
/*                reset ds18b20                      */
void ds_reset_1(void)
  unsigned char idata count=0;
  DQ1=0;
   time_delay(240);
 time_delay(240);
  DQ1=1;
  return;
void check_pre_1(void)
     while(DQ1);
     while(~DQ1);
         time_delay(30);
void read_ROM(void)
 int n;
 ds_reset_1();
  check_pre_1();
  wr_ds18_1(0x33);
  for(n=0;n<8;n++){ROM[n]=rd_ds18_1();}
/*      Read a bit from 1820      位读取             */
bit tmrbit_1(void)
        idata char i=0;
     bit dat;
     DQ1=0;_nop_();
        DQ1=1;
   _nop_();
   _nop_();
   _nop_();
 _nop_();
  _nop_();
   _nop_();
   _nop_();
   _nop_();
        _nop_();
  _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
     dat = DQ1;
        time_delay(50);
     return dat;
/*                read a bety from ds18b20 字节读取  */
  unsigned char idata i,j,dat=0;
     for(i=1;i<=8;i++)
         j=tmrbit_1();
         dat=(j<<(i-1))|dat;
     return dat;
/*         write a bety from ds18b20   写字节        */
     signed char  idata i=0;
     unsigned char idata j;
     bit testb;
     for(j=1;j<=8;j++)
         testb=dat & 0x01;
         dat = dat>>1;
         if(testb)
              DQ1=0;
               _nop_();
       _nop_();
              DQ1=1;
            time_delay(60);
         else
              DQ1=0;
              time_delay(50);
              DQ1=1;
               _nop_();
       _nop_();
int get_temp_1(void)
  unsigned char idata a=0,b=0;
  unsigned char idata i;
  EA=0;
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0x44);
  while(BUSY1);
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0xbe);
  a=rd_ds18_1();
  b=rd_ds18_1();
  i=b;   /*若b为1则为负温   */
  i=(i>>4);
  if(i==0)
   f=0;
   TMP=((a>>4)|(b<<4));
  a=(a&0x0f);
  if (a>8)
   TMP=(TMP+1);
  else
   f=1;
  a=a>>4;
   b=b<<4;
   TMP=(a|b);
   TMP=~TMP;
   TMP=(TMP+1);
  EA=1;
  return(TMP);
int get_temp_d(void)
  unsigned char idata i,m;
  EA=0;
  ds_reset_1();//复位
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0x44);
  while(BUSY1);
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0xbe);
  a=rd_ds18_1();
  b=rd_ds18_1();
  i=b;   /*若b为1则为负温   */
  i=(i>>4);
  if(i==0)
   f=0;
  a=(a&0x0f);
  TMP_d=a;
  else
   f=1;
   a=~a;
   a=(a+1);
   b=~b;
   b=(b+1);
   m=a;
   a=a>>4;
   b=b<<4;
   TMP=(a|b);
   m=(m&0x0f);
   TMP_d=m;
  EA=1;
  return(TMP);
